Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 29th November 2006, 06:36 AM   #1
seilee is offline seilee  United States
Default Transducers for a spring reverb
I'm looking to make a slinky reverb like the one laid out on http://sound.westhost.com/project34.htm, but I don't really know anything about transducers and wanted to see if I could get some recommendations. Also, is there anything that I should do differently if I use a large metal plate instead of the spring?
Old 5th December 2006, 05:30 AM   #2
Brett's Avatar
Default Re: Transducers for a spring reverb
I'd buy a reverb tank with transducers myself. They're quite cheap.
Plate reverbs can be done, but I've only ever seen them in studios and have been large a couple of sq m or so. Audio Amateur did a plate reverb project around 1980 or so,.
Old 5th December 2006, 07:57 AM   #3
dnsey is offline dnsey  United Kingdom
Some springlines used standard crystal phono cartridges as transducers.
Old 5th December 2006, 02:56 PM   #4
Gold_xyz's Avatar
many reverb-tank have two magnetic transducers
with moving magnet system.
(The magnet is fixed to the extremity of spring)
http://www.accutronicsreverb.com/
bye
My English originates from here
SR-101 Pioneer Spring Reverb StrangeDesign Tubes / Valves 13 27th June 2010 02:57 PM
Mixing circuitry especially with spring reverb akis Solid State 2 30th July 2009 12:20 PM
building spring reverb Redfoxfur Instruments and Amps 26 24th June 2009 04:07 AM
Spring Reverb Units TGRANT Solid State 11 4th March 2009 11:31 PM
Spring Reverb transformer ThSpeakerDude88 Tubes / Valves 6 18th April 2007 03:17 AM
Page generated in 0.07865 seconds (72.30% PHP - 27.70% MySQL) with 10 queries
