low THD guitar preamp - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th June 2006, 12:29 PM   #1
Antonix is offline Antonix  Italy
Default low THD guitar preamp
I have to project a tube preamp for acoustic and jazz guitar.
I have studied several schematics from various brand like Fender, Marshall, Peavey etc.
All this brand have circuits with never NFB and THD near 5-8%.
I whant to obtain low distortion by no global NFB but only local NFB.
I have thought something like this:
Old 27th June 2006, 03:28 PM   #2
ALEKSANDR's Avatar
Hello!
If you don't mind, I would like to ask you what soft you used to draw the schematics.
As for the answer, I've built a similar circuit but using only one ECC83 tube (I can see you use one and a half).
ALEKS
Old 27th June 2006, 04:45 PM   #3
kevinkr's Avatar
Your design looks pretty reasonable, however you need to change that 820 ohm in the first stage to something much larger, even with bootstrapping the input impedance will not be that high.
You probably should also take the output directly off of the cathode in your cathode follower, if you are concerned about rfi or external capacitance interacting with the CF, best to put a 1K resistor in series with the output connection. This will eliminate external load interaction with the bootstrap..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th June 2006, 08:52 AM   #4
Originally posted by ALEKSANDR
Hello!
ALEKS
I have used Orcad/pspice for schematics.
I have used 2 tubes 12ax7 because I have to add a second input to the first stage with a separate gain control.
Yes you have reason, I have to change the 820ohm.
[/B]
What you intend to say for directly off of the catode ?
Old 29th June 2006, 04:49 PM   #5
kevinkr's Avatar
Yep, directly off the cathode is what I meant, don't neglect the series resistor though, (min 220 ohms, I'd use 1K) it helps with rf immunity and will keep things stable in the presence of large amounts of external capacitance.
guitar preamp vlljpior Instruments and Amps 17 3rd March 2012 06:21 AM
guitar preamp star882 Instruments and Amps 5 1st May 2007 02:37 AM
Looking for tube guitar preamp high-fi Instruments and Amps 10 24th May 2006 02:27 PM
ne5534 guitar preamp. b<ben>n Chip Amps 7 4th April 2006 02:29 AM
guitar preamp offroadbum Instruments and Amps 0 14th February 2004 11:39 AM
Copyright 1999-2017 diyAudio
