Typical guitar output? - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 11th June 2006, 05:26 PM   #21
wxn is offline wxn  Lithuania
wxn's Avatar
My bass guitar puts out over 2V peaks easily with volume knob turned up and some finger picking. But playing softly keeps the singnal in the hudreds of mV range. But a guitar played heavily, expecially chords, should be capable of output over 1V too.
My 2cents
Nothing is as simple as it seems
Old 11th June 2006, 06:09 PM   #22
DoctorJ is offline DoctorJ  United States
Many guitar amps employ two diodes to the +/- rails at the input stage before the first opamp. Thus any voltage peak higher than 1.4 volts will be dumped into the supply.
Old 11th June 2006, 10:06 PM   #23
teemuk is offline teemuk  Finland
No. In this case it's amplitudes exceeding supply voltage + diode's forward voltage.
Old 14th June 2006, 12:45 PM   #24
Wynand is offline Wynand  South Africa
Wynand's Avatar
Ok. So I've got my guitar at work... can I just put the guitar on a scope (to see output) or must it be connecter to a amp?
Will a normal audio amp work aswell, I don't have my guitaramp at work
Old 14th June 2006, 01:24 PM   #25
Yes, just connect the guitar direct to the scope, the 1Meg input impedance of the scope is perfect for a passive guitar!.
Nigel Goodwin
Old 14th June 2006, 01:57 PM   #26
Wynand's Avatar
Thanks. Tried it.
Built a non-inverting stage with a LM358 with gain 10x.
Plugged this into my LM4780 stereo amplifier.........
Voila.... sound, not brilliant, not good, but there!!!
There is a soft fuzz effect behind the sound of the guitar, but i suspect that it is the prototyping board I'm using!?
Old 14th June 2006, 07:32 PM   #27
Thanks. Tried it.
What input impedance is the preamp?.
Nigel Goodwin
Old 15th June 2006, 08:05 AM   #28
Wynand's Avatar
1Meg
It's a VERY basic circuit. Input to GND = 1M
Gain is with a 10K and a 1K resistor. Nothing else
P.S. Just grabbed a LM358. I figured, its a guitar amp, not a Hi-fi.
I wasn't looking for performance, yet. I want to play around with the circuit first so if I blow something its not a biggie!
Old 18th June 2006, 02:46 PM   #29
Send a message via AIM to rx7speed
just curious here what is the output of the emg-80? my dvm took a dump and I don't have a scope
Old 19th June 2006, 09:18 PM   #30
Don't know about EMG 80, but the EMG 81's output is 1,5V according to manufacturer's specs.
Ground loops & whine on my guitar's output signal! HankMcSpank Instruments and Amps 1 13th August 2008 09:47 PM
Connecting headphones to guitar amp speaker output mike6182 Instruments and Amps 6 21st November 2007 11:20 AM
Typical 2A3 hum? bobhayes Tubes / Valves 31 17th October 2005 02:12 PM
Just your typical DIY enclosure.. ScottG Multi-Way 2 10th July 2005 11:44 PM
cheapest output transformer for a SE EL84 guitar tschrama Instruments and Amps 12 23rd December 2003 11:15 PM
Copyright 1999-2017 diyAudio
