ProCo Rat DIY Not Too Successful - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 17th June 2006, 11:26 AM   #11
the real proco RAT opmp uses just 300uA of current, the LED are obviously disigned to be dimm, as it saves power... the RAT not only sounds very good, is it goes a long way on one battery..
then again, I have a second generation RAT, and the led is dimm when switched off, and quite bright when switched on....
grzz,
Thijs
Old 17th June 2006, 04:46 PM   #12
I don't know if these different generations have different valued volume pots. The millenium switch can't be used for every value of pot, it has to be configured for each value.
Old 17th June 2006, 04:48 PM   #13
You are only talking about a couple of milliamps between bright and dim LED, replacement with a "ultrabright" LED which needs less current would sort out the dim LED problem.
Another successful GM JX92 ML-TL _henry_ Full Range 17 27th December 2004 12:14 PM
Successful Repair JDeV Multi-Way 5 16th June 2003 01:46 AM
Copyright 1999-2017 diyAudio
