Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 9th May 2006, 06:33 PM   #1
spirus is offline spirus  Greece
Default I could use some help with this Coronado II bass
I recently purchased a Fender Coronado II. The previous owner said it’s fully working except for a frozen pot! And indeed the only thing wrong about this bass is the certain pot that doesn’t move a bit!
I’d like to replace it with a new one but I seem to find difficulty as to how such an effort can be accomplished! I mean how can I replace the pots? If I unscrew them will they fall in the body as the pickup switch or not? I unscrewed the pickup switch and I managed to dig it out after a lot of effort. Will the same thing happen with the pots?
Any help???
Old 9th May 2006, 07:23 PM   #2
leadbelly's Avatar
Default Re: I could use some help with this Coronado II bass
Yes, they will fall in. Basically, with these types of instruments, you need to either work through the f-hole, or for major work, actually remove the top! Luthiers have all kinds of nifty tools made up for this purpose.
This repair isn't for the non-handy or the faint of heart, but I would go through with it. Be prepared to actually have to undo more than just that 1 pot to get enough play to bring the wires out through the f-hole. I suggest you do a big web search on DIY repair of semi-hollowbodies.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 9th May 2006, 10:33 PM   #3
poobah is offline poobah  United States
poobah's Avatar
Take some pieces of strong string and tie them around the neck of the guitar. Before you do anything you can tape or hot glue these strings onto the pots and switches.
most all the parts will come out through a pickup hole.
Old 9th May 2006, 11:37 PM   #4
Trout is offline Trout  United States
Trout's Avatar
I Replaced a few F Body pots with a fairly simple tool.
I got some silicon fuel tubing from my local hobby shop, Pressed it over the shaft of the pot and snaked it through. I beleive it was large aerotrend brand, Very Firm made for press fit fuel connections.
I was just able to slide the nut over the tubing after attacked. I had a 5 ft peice, I left it hanging in the cut out and used it to pull the new pot back in.
It worked, Simple, But Scarey
Old 10th May 2006, 05:10 AM   #5
Default may god help me...
so after all, what I most fear is true...
this should be one of the most daring replacements I have to make!
I don't think the luthier idea is as good as it sounds ...
i fear they might end up damaging the instrument and then what should I do? take their heads off?
i will probably try to find a way pull the pot through the pickup hole but first have it tighten to a string that I can pull back with a new pot!
thank you so much guys...
hopefully i will accomplish my mission in less than an hour....
best regards...
Dipole bass or Ripole Bass? MJL21193 Subwoofers 13 15th September 2008 07:42 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
Wow ! Bass from no bass ....! ashok Subwoofers 14 15th November 2006 10:59 PM
DBA (dual bass arrays) and active bass traps capslock Subwoofers 3 20th August 2006 12:52 PM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Page generated in 0.08539 seconds (72.75% PHP - 27.25% MySQL) with 10 queries
