| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hello all!
I like the sound of my Rhodes, but I dislike the output..... is there a preamp I can add to my rhodes wich is quite easy to build? Thanks! |
#2 |
If you just want to run the output from the piano pickups into something, most any little preamp will work. You want full range rather than something for guitar. A mic pre would work, or a small mixer, like a Mixpad or similar. The mixer would add EQ and other features a plain mic mixer might lack. Then again of your EQ and other stuff will be covered by a full size mixer elsewhere, then a simple preamp works.
#3 |
Thanks!
| Fender 6L6 Amp... HELP!!! | mjarve | Tubes / Valves | 18 | 28th November 2010 06:06 PM |
| Fender Pro Amp | atmars | Tubes / Valves | 1 | 23rd November 2008 01:30 AM |
| fender amp question | rukr1 | Solid State | 28 | 29th December 2007 05:24 PM |
| Fender help | Docc25 | Instruments and Amps | 1 | 11th July 2006 01:16 PM |
| LDR in Rhodes piano (help!) | Magnetmaz | Instruments and Amps | 1 | 27th July 2004 06:55 AM |
| Page generated in 0.07117 seconds (63.99% PHP - 36.01% MySQL) with 10 queries |
