need help for Marshall PCB - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 24th April 2006, 01:44 PM   #1
Default need help for Marshall PCB
hi all
i just converted this marshall schematic ( power amp section only ) into pcb lay out :
http://www.drtube.com/schematics/marshall/1986mk2jp.gif
i convert it manually on paper , and then draw it with diptrace , i checked it out so much , but it s so easy to make a mistake and dont see it as u know , does any body see any errors on it ?
thanks
at sure i ll make it much compact but just wanna check it out this first version of it , then try to change it ,
( i removed the 47k resistor from 16ohms output of transformer cuz my transformer doesn t have the 16 ohm out put )
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 24th April 2006, 03:02 PM   #2
audiomanics's Avatar
I found one: just in the middle you placed a 470K resistor... in the schematic this one is 470 Ohms.. I assume you place the components of the first tubes on a different board??
Kees
Old 24th April 2006, 08:19 PM   #3
thnx , i ll build an ampeg v3 pre amp instead of this marshal
Marshall 4x12 cab tareqx2 Instruments and Amps 22 18th September 2007 10:47 AM
Marshall AVT50H PAJW Instruments and Amps 2 1st August 2007 02:26 PM
Marshall MS-2 Andronico Instruments and Amps 12 23rd July 2007 01:50 PM
mg 100 dsp marshall amp topkat Chip Amps 0 24th October 2006 10:31 PM
MG 15DFX marshall amp darkpgn Instruments and Amps 1 9th June 2005 07:53 PM
Copyright 1999-2017 diyAudio
