Tube Compressor - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 15th April 2006, 04:00 PM   #21
Default Re: it didn t work :(
Originally posted by Ahmad_tbp
it didn t work ...
i changed the two input couplage caps to 47n and the output couplage cap to 1uf , and use it before pre ,
it didn t work !
any idea ???????
Have you made sure it's all connected properly?, try fault finding, it's a very simple circuit.
When you say it doesn't work, what doesn't work?.
Nigel Goodwin
Old 15th April 2006, 04:08 PM   #22
i mean it doesn t work correctly :P ...
it s a very loud sawtooth or square wave around 80/100 hz ( i m not sure bout the wave and freq , i don have a scope ) comin out of it , but when i turn the 2nd pot (25k) all the way down the noise become silence suddenly , i connected my signal generator to it , very very little pulsin sound come out of it !!!
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 15th April 2006, 04:19 PM   #23
Geek's Avatar
Sounds like you have the + and - inputs reversed.
Old 15th April 2006, 08:53 PM   #24
+ and - inputs reverse ? no ...
i checked all the wires and pcb again and again ,, no error i think ,,, any idea ?
Old 15th April 2006, 09:59 PM   #25
Geek's Avatar
Ummm, what else can cause this... transistor in backwards or one that's leaky, R/C time constant too short (getting FB through the LED/LDR), which can also happen with correct R/C if the LDR is in the wrong spot in the circuit and finally, the 3900 is a hi-Z device - incorrect wire dressing wreaking havoc.
Old 15th April 2006, 10:11 PM   #26
no man ! i m talkin bout the valve comp/limiter schematic i sent , i built it , ...
here s the pcb , maybe i make a mistake and didn t seen it
Old 16th April 2006, 12:47 AM   #27
Geek's Avatar
no man ! i m talkin bout the valve comp/limiter schematic i sent...
Ah, OK!
Then what you're describing is powersupply ripple. It needs a superclean supply and good decoupling.
Old 16th April 2006, 10:14 AM   #28
Just wondering?, why make a PCB and then not mount the valve holders on it? - it seems rather a waste of time?. If you're mounting the valve holders on a chassis, why not hand wire them? - in classical valve fashion (particularly for something as simple as this).
The old TV manufacturer KB actually manufactured valve colour TV sets all hand wired without PCB's! - incredible what you can do!.
Nigel Goodwin
Old 16th April 2006, 08:08 PM   #29
cuz it s just a test pcb , i ll built preamp,comp and tone control on one pcb ...
and u said hand wired .. does it make more noise ???
and is my problem is my power supply ?
Old 16th April 2006, 08:31 PM   #30
wat if i use this power supply ?
http://www.diyaudio.com/forums/attac...amp=1144698398
Any recommendations for tube for vari-mu compressor? leadbelly Tubes / Valves 5 8th April 2009 09:23 PM
Compressor diy XXLPeanut Instruments and Amps 5 14th June 2006 11:55 PM
DIY air compressor. help needed peterr Everything Else 4 8th September 2005 02:10 PM
Schematic for tube compressor/sustain ? whatsnext Instruments and Amps 6 23rd August 2005 05:52 PM
Tube compressor problem! coony Tubes / Valves 7 1st February 2005 09:08 AM
Copyright 1999-2017 diyAudio
