Tube Compressor - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th April 2006, 11:33 PM   #11
Geek's Avatar
Originally posted by Ahmad_tbp
and thnx geek for link at sure i ll try the comp section if i find ic here
You're welcome!
If you can find an IC, I have PCB's available for the compressor circuit
Old 13th April 2006, 11:43 PM   #12
If I could suggest something- go for LED-photoresistor compression...
i saw a circuit for that somewhere but never try it before , but i will ,
the compression is so important for bass ,so i ll try and try to find what i m lookin for ! lol
Ha! I knew it! I knew it!
yeaaaaaaaaaaaaaaaahhhhh death , Chuck Schuldiner R.I.P , Sure u know him yeah ?
this band is like a god for me , i really like him , a true face for metal music , here s my another favor quote from Chuck : beware of the sharp edged weapon , called human being !!
RIP Chuck .... :|
thnx geek but it s impossible for me to buy anything from here lemme see if i can find the ic , converting the schematic to pcb layout is not that hard for me thnx
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 14th April 2006, 09:36 AM   #13
to Nigel Goodwin : infact most bassists are into solid state cuz they need lotsa power , but wat can ever compare with the warm and alive sound of a tube ? and cuz of that most amps are usin valves for pre and solid state for power , i prefer all tube my self
Depends if you like a clean sound, or the frequency limited and distorted sound from a valve amp?. Personally, for bass, I prefer a clean sound - if you want distortion occasionally add an effects pedal?.
Probably one of the biggest valve advantages is the volume from them?, distorted sound is far louder than clean sound - to compete a transistor amp needs 3-4 times the power!. You can't clip a transistor output stage, it sounds absolutely horrible, but it's standard practice with a valve amp, resulting in a much louder sound.
Nigel Goodwin
Old 14th April 2006, 09:55 AM   #14
yeah most of bassists think bout valves when they need a distorted sound , but i need absolutly clean sound and still stick with tubes ! lol , i never heard a clean solid state sound that can compare with the clean sound of a tube , but as u said it all depends on taste ,,, i m playin deathmetal , and most deathmetal players like distorted sound for bass , but i m not that s why i m lookin for a comp/limiter
Old 14th April 2006, 04:57 PM   #15
Geek's Avatar
You've had some real crummy equipment then to get that idea
Old 14th April 2006, 05:59 PM   #16
can i use this comp/limiter after preamp ???
Old 14th April 2006, 08:07 PM   #17
What do you think the characteristics of a valve amp are?, poor frequency response and high distortion (mostly even harmonic), presumably that's what you like about them?.
Nigel Goodwin
Old 15th April 2006, 09:03 AM   #18
??? i think it s diffrent from wat we here from tubes .. why ?
and so , can i use this comp/limiter after preamp ???
Old 15th April 2006, 09:09 AM   #19
No, that's the sound people are looking for from valves, the 'warm' sound people like is basically frequency limitation and distortion.
Bear in mind, we're not talking about objectionable distortion, even harmonic distortion is fairly 'musical' - even when over driving valve amps and probably running at 100% distortion.
I presume so, but you need a power amplifier with a high impedance input to feed it to - or an active DI box before the power amp should work as well.
Nigel Goodwin
Old 15th April 2006, 03:57 PM   #20
Default it didn t work :(
it didn t work ...
i changed the two input couplage caps to 47n and the output couplage cap to 1uf , and use it before pre ,
it didn t work !
any idea ???????
Any recommendations for tube for vari-mu compressor? leadbelly Tubes / Valves 5 8th April 2009 09:23 PM
Compressor diy XXLPeanut Instruments and Amps 5 14th June 2006 11:55 PM
DIY air compressor. help needed peterr Everything Else 4 8th September 2005 02:10 PM
Schematic for tube compressor/sustain ? whatsnext Instruments and Amps 6 23rd August 2005 05:52 PM
Tube compressor problem! coony Tubes / Valves 7 1st February 2005 09:08 AM
Copyright 1999-2017 diyAudio
