Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 7th April 2006, 03:41 AM   #1
Default Would this work ?
Could someone look this over for me ?
I've never done any circuit design, this is basically a copy-paste job from various sources on the Net.
I'm wondering whether this will work or not.
What I'm looking for is a unity gain mixer able to sum some signals in my guitar amp's FX loop.
Basically I wan't to split the guitar signal into the Amp input and into the "Shimmer" input (will this method work, or is there a better way of doing this ?),
then add the FX-Loop-Send signal to the "Shimmer"-Return signal and mix that into a Looper.
Finally take the Looper Return signal, mix that with the "Shimmer"-path (paralell with the previous chain) and feed the Amp's FX Loop Return
So could anyone look over my schematic and let me know if they see any problems,
cheers
LPS91
Old 3rd May 2006, 11:06 PM   #2
try a standard 4 ch. mixer
Old 4th May 2006, 01:58 AM   #3
Well that's sorta what I'm using now,
I'm looking to build myself a custom "black-box" patchbay/mixer, that I could have on a pedalboard.
LPS91
Old 4th May 2006, 02:14 AM   #4
Optical is offline Optical  New Zealand
from a brief look - yes it would work but it is not ideal..
you should have a buffer for the raw guitar signal before splitting it up, and you have two buffer sections on each channel, you only need one!
or maybe im missing something, why would you need those two section with the slightly different cap in the feedback path in each? more roll off? you could always put a shunt cap on the input to get the same effect
TL and JBL could it work Flodstroem Multi-Way 47 14th July 2006 03:03 AM
Will This Work? sousmielie Class D 6 27th December 2005 05:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 05:33 PM
Would this work? JoeBob Solid State 5 18th July 2003 03:40 PM
Page generated in 0.07874 seconds (70.84% PHP - 29.16% MySQL) with 11 queries
