DIY reverb?
Well, I can say that I've finally done something that everyone's grandparents have bragged about: Fixing a messed up amplifier with superglue and rubber bands. (It turned out that one of the connectors was backwards on the reverb pickup; I also added a small bit of rubber as a damper to the reverb coils). Lo and Behold, it worked perfectly.
However, I was curious: How could I go about building something that worked in a similar fashion to a spring reverb in a guitar amp? I'm still working on an electric didgeridoo, and would like to use one to have a didgeridoo's audio output modulate a tone (or set of tones). |
i think you could make a spring reverb pretty easy with maybe a solenoid or speaker coiil attached to the spring at one end and another coil at the other end.
possibly if there is a acoustic part of the digeridoo the vibrations would be enough to get the spring moving, so you could just have a pickup on the spring. |
An added bonus of coil reverbs? Stick an electromagnet next to it, and you have an electronically controlled "wah". |
Slinkies are fun!
http://www.electronicpeasant.com/pro...s/springs.html http://www.electronicpeasant.com/pro...o/thermio.html Take care, Doug |
You can buy reverb assemblies for just 20 bucks... from there you could tear it apart and get all the goodies you need...
Go here ;) |
From curiosity and off topic: anyone played with tapes?
Tapes? Like a tape delay/echo? Had an old tube tape delay years ago that worked okay. It was pretty noisy though. Digital delays are so much better - cleaner. I love my Digitek S-100.
| All times are GMT. The time now is 10:39 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
