Kewl!! And a Q about Guitar cables. - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th November 2002, 07:46 AM   #21
sangram is offline sangram  India
halojoy:
I love you.
Old 14th November 2002, 08:45 AM   #22
bob4 is offline bob4  Germany
bob4's Avatar
Location: (Black Forest, Germany) currently southern Finland
Cool bad spelling
sangram,
Originally posted by sangram
Bob: Do you mean capacitance?
You're right samgram, I was too lazy to look up the proper translation
I was referring to your comment on different cables altering sound rather than to the noise prob.
it almost sounds like the crackle of old and dusty LPs.
In that case I think it's all about plugz'n'socketz, as shiFty pointed out.....
greets,
bob
Old 14th November 2002, 11:35 PM   #23
mrfeedback's Avatar
Default Handling Noise.
If you are getting a crackling/rustling sound when flexing your cable it is due to the internal wires moving with respect to the shield causing change in capacitance, and hence audio noise output, especially in a high impedence, low level circuit such as guitar preamp input.
A tightly woven braided shield reduces this.
Better still is coax with a conductive pvc layer over the inner wire dielectric, like the photos I posted.
This cable is exceptionally quiet.
Eric.
Old 15th November 2002, 12:13 AM   #24
pinkmouse's Avatar
Sangram.
When I was a touring guitar tech, I always used Van Damme instrument cable, single core plus sheath, relatively quiet, yet very robust.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 15th November 2002, 12:20 AM   #25
halojoy is offline halojoy  Sweden
On Hiatus
sangram, friend
You haven't considered a little preamp in the guitar
just to raise the level a bit.
Can be powered by battery. That is what I would do.
A good OPamp is small and takes not many mA current.
Old 15th November 2002, 06:44 AM   #26
I checked extensively last night.
The noise is microphonic. Definitely. On tapping the cable, it sounds like a mic is being tapped. On flexing it, you get the 'whooshes' generally associated with the movement. It happens with or without the guitar plugged in.
The amp is a Marshall G30RCD solid state with two channels. Even with the volume at 0, it produces some sound so I suspect something wrong inside the amp, but I'm not sure, and I'd hesitate to open it.
The same cable is dead quiet on other amps, and the Marshall does not make sound with any other cable. Wierd! Maybe they just don't get along...
Old 17th November 2002, 08:37 PM   #27
tmc is offline tmc
tmc's Avatar
the only time i have invested time into DIYcable has been in my buds studio and when i was doing live sound ( we rigged up snakes to minimize setup/teardown times, as well as tidy thangs up abit )
I would opt for top o the line cabling unless you are getting ready to take your rig on the road.
spend the money on the cables and invest the time on the music/recording.
taxes are for corporations
Old 17th March 2004, 06:13 AM   #28
Default DIY guitar cables
i've also been trying to find some info on the web about best way to make up guitar cables. can anyone post some pics or point me toward some resource i have missed. thanks
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 24th April 2009 12:43 AM
ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! ssabripo Everything Else 3 26th October 2006 03:33 PM
Looking to make Guitar cables kimbahpnam Everything Else 0 6th November 2004 09:25 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 08:14 AM
Kewl new Technology: Da5id4Vz Everything Else 1 8th October 2003 10:08 PM
Copyright 1999-2017 diyAudio
