Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th January 2006, 08:24 PM   #1
Default need suggestion on graphic eq for bass
hi , i just found boss ge7 ( 7 bands graphic eq for guitar ) i wanna use it for my bass , and i need to change the frqs to these :
40-120-400-500-800-4k-10k
so how can i change the caps to give me these freqs ?
thnx a lot ...
( the ge7 circuit s here : http://web.tiscali.it/boxsmt2clone20...k_boss_ge7.htm )
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 26th January 2006, 09:15 PM   #2
leadbelly's Avatar
http://sound.westhost.com/project64.htm
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 27th January 2006, 06:22 AM   #3
hi .. i want to change these ge7 freqs to bass guitar range .. i review the Rod Eliot project 64 , but i couldn t understand which values i should change .. anybody help ?
Old 27th January 2006, 08:47 AM   #4
as bass is tuned an octave below a guitar the simplest
thing to do is double the value of all the capacitors used
for EQ. You also need to double any coupling capacitors.
/sreten.
Old 27th January 2006, 09:14 AM   #5
sorry i m so new in electronic :P ..
u mean i should double the value of c1-c2-c4-c5-c7-c9-c10 ?? wat bout c3-c15-c6-c14-c8-c10 ??
and which one s couplin cap ?
Old 27th January 2006, 10:25 AM   #6
There seems no point in changing it at all?, why not just buy a bass one?, check the new (very cheap!) Behringer pedal Here.
Nigel Goodwin
Old 27th January 2006, 11:20 AM   #7
cuz i cant find any bass effetct pedal here ... unfortunately ...
u can find any guitar effect , anything u want bout guitar ... but lack of bass stuffs , ...
Old 27th January 2006, 11:32 AM   #8
Hmm.....
asking this question perhaps you should just buy a cheap pedal,
its a lot easier, and it will work.
I suspect the results of your efforts might be a very dead pedal.
But you can safely ~ double every capacitor in the top half of the circuit.
(except the the low noise mod capacitor)
You can reuse most capacitors somewhere else e.g. C8 becomes C14.
/sreten.
Old 28th January 2006, 06:44 AM   #9
u mean tantanium caps , right ? :P
Suggestion for a bass preamp.. Dxvideo Chip Amps 4 29th July 2008 01:47 PM
any suggestion for limiter and compressor for a bass guitar ? Ahmad_tbp Instruments and Amps 4 27th January 2006 09:53 PM
Need some Revelator mid-bass system design suggestion F.L. Multi-Way 1 25th April 2003 08:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
