Alembic F-2B - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 16th January 2006, 03:31 PM   #1
mbonus is offline mbonus  Croatia
Default Alembic F-2B
hi everyone!
I'm new to tube projects,but i recently
found schematic of this bass preamp
and i want to build it for myself.
Like i said,i don't have experience with
tubes so i will be grateful if someone could help
me with this project. I found only this scheme
so i don't know some details...
in power supply i don't see gratz,just one diode.
is it ok to have only half-wave rectifier?
which power of transformer and voltage on secondary do i need?
thx!
here is the scheme:
Old 16th January 2006, 04:00 PM   #2
ilimzn is offline ilimzn  Croatia
It is a voltage doubler, not a half-wave rectifier, note capacitor in series with transformer winding. My guess at the winding voltage would be about 100VAC
Old 3rd March 2006, 04:03 PM   #3
Moondog is offline Moondog  Netherlands
I am also starting to build a pre-amp, based on this F-2B schematic. Alembic is using the Stancor PS-8415 transformer which has 125V secundaries.
Please note the schematic you posted has faults! Pins 6 and 8 of the tube are mixed up!!
Old 3rd March 2006, 04:55 PM   #4
kevinkr's Avatar
Definitely a half wave voltage doubler, and I concur that the transformer secondary ought to be in the 100V - 120V range.
The pins on the first section of the 12AX7 are reversed, plate =6, grid=7, cathode=8 on a 12AX7A.
It is important to keep that power transformer away from the 12AX7.
Build the thing in a nice metal box, preferably aluminum as it is much easier to work than steel, and using a socket with shield for the 12AX7.
For this application I would recommend the Sovtek 12AX7LPS, it's quiet and the spiral filament construction cancels the hum inducing ac magnetic field around the filament.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Alembic F2-B phil mailloux Instruments and Amps 101 12th October 2011 02:07 PM
Alembic F2-B project gone cookoo Nordskov Instruments and Amps 3 17th June 2009 08:03 PM
Alembic SF-2 Super filter Schematic ? FUCHSAUDIO Instruments and Amps 7 29th July 2007 07:32 PM
Pre/PS ala Alembic croat47 Instruments and Amps 3 16th March 2006 01:50 PM
Copyright 1999-2017 diyAudio
