Guitar Amp HUUUM with an MP3! Reverb Problem - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 30th December 2005, 03:32 AM   #11
Gene, about half of the background hum went away when I grounded the reverb pot at the middle pin. It's certainly playable when I ground it, and I have to say the amp sounds very good! Nice clean tones and the distortion is pretty smooth. Much better than I expected. It will also rattle the windows in my living room with ease!
By the way, in the mp3, the idle buzz sounds like it does in person, but hum created by turning the reverb control makes a deeper bassier hum than it sounds in the clip.
I took a look at the reverb spec calculator, looks pretty cool, but my tank is a 2 spring Belton unit. The Belton is physically longer than the Accutronics 2 spring units. Luckily there is a phone number to Belton in Korea on the unit. I played around flip flopping the grounding and such on the reverb pan with no change.
I would really love to get the reverb hum down and play some guitar. Any more thoughts or suggestions?
Thanks,
Ted
Old 30th December 2005, 03:12 PM   #12
Trout is offline Trout  United States
Trout's Avatar
Ted,
Can you post a picture of the inside of the chassis?
My thought is looking at the schematic, Bypass the reverb section. But of course that pretty much depends on the chassis wiring. Is this printed circuit? Tag Board? Point to Point?
If the reverb stage is fully bypassed, Then maybe you can locate the other hum source " IF " there is one.
( Just my opinion )
I never use spring reverbs, They are even in the best amps I have played less than ideal, Noisey,Common source of feedback, And lord knows terrible if the amp is positioned near the drummer on a Knock Down bouncy stage.
I am far from an expert on this, But for recording I use a no effects setup at the amp, And add things like reverb or chorus with Cubase SX recording software. If I am playing out I use effects pedal for what little I ever need.
Rarely do I ever use much reverb, Generally I just breath on the knob at the pedal to take out a bit of the dryness.
Of Course opinions vary on this.
Looking at that schematic, I bet that baby has a great clean sound!
Gene
Old 31st December 2005, 06:23 PM   #13
aletheian's Avatar
Good point. The placement of the reverb transformer and the tnk itself is very important as well.... as is lead dress. Tube reverb in amps is a pain in the A** to get right, but once you get it, you should be fine.
Heghlu'meH QaQ jajvam!
problem with old reverb - help? 2SK30 Digital Source 5 22nd July 2008 10:56 AM
Problem with my marshall jcm2000 tsl 122 100W Combo, Reverb on full after warm up craymorr2003 Instruments and Amps 1 12th April 2008 08:50 PM
I need a simple ss reverb for a ss guitar amp. yeto Instruments and Amps 8 18th January 2006 06:54 AM
reverb tank in a guitar amp connection dud_wity Instruments and Amps 1 19th June 2004 12:58 PM
Copyright 1999-2017 diyAudio
