Help With Peavey Bass Cab - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd November 2005, 11:35 PM   #1
Default Help With Peavey Bass Cab
Ok I recently upgraded my bass amp from a ****** silvertone amp to an all peavey one. The head is no problem but the speaker cab (4x12) has one, the bottom two speakers hardly move, even at full voulme. At first i thought the speakers werent hooked up, but that wasnt the case, so i put in a heavier wire but still nothin. They still make sound but nothin compared to the top two speakers. if any one has an idea as to y this is happenin that would be great.
Old 2nd November 2005, 11:40 PM   #2
Speakerholic
Cal Weldon's Avatar
Hi Eddie,
I had to manually edit your post as you tried to circumvent the spelling auto censor. Please don't do that again. Welcome to the forums.
Cal
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd November 2005, 03:43 AM   #3
wxn is offline wxn  Lithuania
wxn's Avatar
Perhaps there is a crossover of some kind. And those speakers simply don't play all frequencies
Nothing is as simple as it seems
Old 3rd November 2005, 05:15 AM   #4
Enzo is offline Enzo  United States
Not usually a crossover in a 4x12.
What cab is it?
Several things come to mind.
If there are two jacks, could this cab be a mono/stereo cab? That means plugging into the mono jacks gets all four speakers, but plugging into the stereo jack works only two of them.
Are all four speakers of the same type and same impedance? If the two speakers are odd, they might not be working for that reason. Someone may have replaced the original speakers with who knows what.
Are all four speakers wired in phase? That means do they all move the same direction together? Plug a cord into the jack, and touch a 9v battery to the other end of the plug. Touch the tip of the plug to one battery terminal, then lower the shaft of the plug dwon to touch the other terminal. This will make the speakers all move a little and make a thump or pop sound. WATCH THE CONES. They should all four move the same way. If one moves the opposite direction, it is wired backwards. Swap the two wires going to it.
While you are checking phase, make sure all four speakers are functioning. When music is playing, the air currents will make dead speakers move. The battery test will check a speaker for function. You can test individual speakers with the battery too.
If those two dead speakers are wired in series, if one of them is open, both of them will go silent. Use the battery to test each one.
Is the wiring correct? Especially with the common series/parallel wiring arrangements, the mess of wires can be confusing, and it may not be correct.
Old 3rd November 2005, 08:16 PM   #5
ok well i dont really know alot about the cab....all i know is that its a 4x12, made in 1982, all the speakers are the same make, im pretty sure there are all 16 ohms and there wired in parallel.
I tried the battery thingy and still that same thing happens, the top two are noticeably moving, while the bottom two (still makein a pop sound)are no movin. I also thought i might be hearing the other two but if you touch the bottom two you can feel movement.
Old 4th November 2005, 02:20 AM   #6
So pull the wires off each speaker and test it individually with a battery. You could just have a couple dead speakers.
Old 4th November 2005, 08:00 PM   #7
ya i did that and all the speakers work
Old 5th November 2005, 03:48 AM   #8
If all four speakers work individually, but not when in the cab, then the cab is wired wrong.
Old 5th November 2005, 04:41 AM   #9
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
And if it is really easy to connect and disconnect the wires then its even more likely someone messed them up.
We need a photo or a diagram and we'll get you fixed up in no time (maybe!?)
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 5th November 2005, 06:44 PM   #10
ok well from what i can see the cab is hooked up properly, nothing loose things like that. i drew a pic so show what the wiring is like (ya i know i cant draw) i hope this helps
Peavey Max 115 Bass amp Goldpanner Instruments and Amps 18 24th November 2016 08:51 AM
Peavey Mark III Bass 400 B/G? PA Problem soapboxsam Instruments and Amps 3 27th May 2009 05:55 AM
peavey cs 800 erockin Instruments and Amps 1 30th March 2007 11:38 PM
Peavey MarkIII bass head schematics??? Zero Cool Instruments and Amps 0 2nd February 2007 02:44 AM
need schematic: peavey minx bass amp 30 watts elementx Instruments and Amps 1 12th July 2006 11:59 PM
Copyright ©1999-2017 diyAudio
