Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 7th October 2005, 02:40 PM   #1
Send a message via ICQ to karahara
Default Opamp Guitar preamplifier
Hej to all guitar-players.
Im planning to build a Opamp based preamplifier for my guitar(complete SMD). The circuit should act as an impedancetransformer(don't know the right word, sry) with about 10dB gain.
Here's the schematic:
Could you check the values which i plan to use?
Which Opamp fits my needs: SingleOpamp, SIL-8, Low power consumption? TL061?
It will be powered with an 9V battery.
Thanks in advantage for your answers.
julian
Old 8th October 2005, 09:29 PM   #2
wxn is offline wxn  Lithuania
wxn's Avatar
It seems fine. Though I would change the output resistor to something like 100ohm and use an opamp with lower noise (42nV/vHz is quite a lot for such application)
Nothing is as simple as it seems
Old 9th October 2005, 01:30 AM   #3
Brion55 is offline Brion55  United States
Send a message via Yahoo to Brion55
If you plan on using just one 9V battery, the op amp needs to be referenced to 1/2 the supply voltage in order for it to swing rail to rail. See the drawing I attached. You don't need the volume pot if you don't want it.
How do I put the smoke back in this thing?
Old 9th October 2005, 04:40 PM   #4
Allright, I searched a bit for an good Opamp and found
The OPA234 series low-cost op amps are ideal for single-supply, low-voltage, low-power applications.
So, with this opa, must i use the 1/2 V+ thing?
Changes:
C2-->0,68µ to 0,1µ
C3-->0,68 to 0,1µ
R4-->1k to 100 Ohm
Old 9th October 2005, 08:23 PM   #5
Ok, after Reading through the "Op-Amp Design Reference" from TI I came to the decision that I need a split supply(wonder )
So I thought this would be nice:
Because I want to use as less space as possible I want to leave out D1/R1(useless) and C1/C2(does that work without?)
Old 9th October 2005, 08:34 PM   #6
wxn's Avatar
D1/R1 can surely be left out. But the caps should stay. Though lower capacitance would do I suppose.
About the opamp, I was thinking about this one:
http://www.analog.com/en/prod/0,,OP27,00.html
Notice how much better all the parameters are. Except for quiescent current... But then again, I'm feeding it from a stationary power supply.
And another, a bit less power hungry:
http://www.analog.com/en/prod/0,,AD8671,00.html
This one looks promising. Even ideal I'd say. And quite cheap
http://www.analog.com/en/prod/0,,OP196,00.html
Old 9th October 2005, 09:05 PM   #7
Hm oky, there should be room for some caps.
I've choosen that Opamp because I've have some of them here and also because of the low quiescent current.
The other parameters should also be ok for audio use, but also I don't really understand all of them.
Old 10th October 2005, 01:27 AM   #8
If you want something simple and low-power, I'd suggest going with a couple JFET transistors instead of some Op-amp.
I designed one with 4 JFETs, that has up to +20 dB of gain, very low output impedance and draws only about 500 µA (max). The plus is that it does have this slightly "tubesque" sound that you can't get with an op-amp. Oh, and after designing your first circuit with JFETs, you start feeling like a grown man. lol.
I'll post the schematics if that ever interests anyone (commercial use forbidden, of course).
Old 10th October 2005, 02:23 AM   #9
Optical is offline Optical  New Zealand
I personally am after a preamp such as this with about 40dB gain, minimum power consumption..
I'd like to see your jfet design
Old 10th October 2005, 02:56 AM   #10
Ok, there you go.
Might need some refinement, but it's already nice. I built one prototype so far and installed it in my guitar - it works fine. (The version in my guitar is slightly modified though, I added a "tone control", but the base circuit is the same.)
Should work right "out of the box": nothing to tweak here. The variable resistor allows to set the gain, but any position should yield a relatively low distortion level. As you can see, it was actually meant to be an internal preamp for active pickups - but I ended up using it as a simple on-board preamp on my guitar. (I did make an active bass pickup, but that's another story entirely...)
The JFETs are SST201's here for the SMD version. Use J201's instead if you want to build a through-hole version of this. Other JFETs may work, but I wouldn't count on it without modifying the components values (and the power consumption) a bit...
tiny opamp based cct to amplify six (piezo) guitar pickups? HankMcSpank Solid State 9 23rd February 2009 09:29 PM
anyone with a low noise preamplifier circuit for guitar? winner Instruments and Amps 3 14th January 2009 06:51 AM
Guitar USB preamplifier/interface Rufinus Instruments and Amps 11 30th November 2007 03:56 PM
Choosing an opamp for guitar direct box. Giora Parts 5 18th June 2007 12:38 AM
Guitar Buffer OpAmp Question... Upionics Instruments and Amps 2 19th October 2004 12:00 AM
Page generated in 0.12485 seconds (79.30% PHP - 20.70% MySQL) with 11 queries
