Fender power transformer help - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 11th September 2005, 08:05 AM   #1
layt is offline layt  Australia
Default Fender power transformer help
Ok heres my problem, the deluxe reverb Fender transformer I have is configurable for different voltages 100V,220V and 240V but im not exactly sure how to hook it up for 240V as theres no instructions. But I did find that Fender supposedly use the same wiring for all there power transformers, with the tonemaster power transformer there appears to be a usefull chart but ill see what you guys think. Ive also included links to the actual amplifier schematics. Hope someone can help, thanks guys
Old 11th September 2005, 08:41 AM   #2
cerrem is offline cerrem  United States
cerrem's Avatar
You will need to connect the two primary windings in SERIES..
That would be BLK/Yellow connected to BLK/GREEN ....
Then the 240V voltage is applied to BLACK and BLK/RED....
Chris
Old 12th September 2005, 07:31 AM   #3
Default have I got it?
So if I join black green to black yellow that makes one side right?, then I join black red to black to use as the other? . As soon as somebody replies ill wire it up and see how I go (I wanna do it now but dont wanna destroy anything either so ill wait, thanks again)
Old 13th September 2005, 05:34 AM   #4
Enzo is offline Enzo  United States
No no no. DO NOT join black/red to black.
As cerrem said, connect black/yellow to black/ggreen. Nothing else connects to them, their only job is to connect to each other. That puts the two primary windings in series. Then connect the 240v mains to black and black/red. One side of the mains to each, NOT connecting them together first. Mains 1 to Black/red, and mains 2 to black.
Now let me throw in a little extra. See the violet wire at top? It should have about zero ohms to the black/red wire under it. That symbol between them is a circuit breaker. There is a thermal breaker inside the transformer. If you want its protection, wire the 240v mains to black and violet rather than black and black/red.
Old 13th September 2005, 07:31 AM   #5
Default whos a big idiot?? ME
Ok ok so I went away and had a think about it and looked back at what cerrum said, then i had a look at my transformer wiring diagram and a hammond one and hey it all made sense when i used my brain!!. My power transformer works well, I measured the voltage on the secondaries and there all fairly close to what they should be. Thanks mate
Old 11th January 2011, 10:59 PM   #6
lexocom is offline lexocom  Georgia
Send a message via Skype™ to lexocom
I have a Fender Frontman 10G input is (120V; 60Hz; 28W). I wish to run it from 220Volts 50Hz. Does the factory transformer support 220 Volts, if not what transformer should i use to replace it.
Volume Surges Fender "The Twin" - transformer going? jl_lensman Instruments and Amps 12 13th May 2016 04:07 PM
Fender Output transformer as an audio amp part zxx123 Instruments and Amps 6 18th January 2005 02:12 AM
buzzing and pop sound when fender power amp is turned on zaboomafoo Everything Else 0 27th August 2004 06:12 PM
toroid Transformer as power Transformer for tube tone Tubes / Valves 7 11th February 2003 09:57 AM
Good price on huge power transformer for power amp. G Solid State 3 15th September 2002 02:23 PM
Copyright 1999-2017 diyAudio
