Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 22nd June 2005, 06:37 AM   #1
brentt is offline brentt  Australia
Default Noobie Electronics
Ive got a few Circuit diagrams for guitar effects pedals and im not sure wat a few of the symbols mean im pretty sure its the same one but id just like to no b4 i make anything ill attach the pic of the symbol
Old 22nd June 2005, 07:34 AM   #2
Apparently its a "Common Point" What the hell is that?
Old 22nd June 2005, 07:39 AM   #3
Frank Berry's Avatar
The symbols on the right prabably represent the ground trace on a printed circuitboard. The symbol at the left is where the circuitboard ground connects to the chassis.
Frank
Old 23rd June 2005, 04:27 AM   #4
Enzo is offline Enzo  United States
Those symbols represent ground or circuit common. There are various ways to draw it, so it may look different in one company's drawings than another's.
The flat line is one, and the upside down pyramid too. Those are what you presented. Ther is also one that looks like a garden rake.
Though we may call it ground, in a battery operated circuit, there may not be an actual connection to ground. it is then simply called the "common" connection. In some parts of the world, they refer to ground as "earth" in the sense that it ultimately connects to something conducting to the actual earth outside.
Old 25th June 2005, 07:18 AM   #5
Default Thanx
Thanx for helping me out with that but now im not sure on another component. Ill add a pic....
Old 25th June 2005, 02:33 PM   #6
Brett's Avatar
It's a variable resistor, or potentiometer, usually abreviated to 'pot'. In the Wah pedal you linked it is the resistor that controls the wah function, and is usually mechanically geared off the pedal lever itself. The same type of device is used in just about all rotary controls on electronic instruments, such as volume controls etc. The long linear channel gains on mixing desks, and the sliders on graphic equalisers are identical in function, it's just that the control moves physically in a different way, ie linear rather than rotationally.
Hotz Potz is a brand name for the part.
Noobie IDSKoT Introductions 1 6th May 2009 02:44 PM
Please help out a Noobie... audio_moksha Tubes / Valves 13 12th November 2006 10:47 PM
A few noobie Q's about box design david_moechnig Multi-Way 6 28th June 2004 09:26 PM
noobie dudemyster Parts 1 22nd January 2004 03:00 PM
Hi from Yet Another Noobie blip Introductions 2 9th March 2003 08:52 PM
Copyright ©1999-2013 diyAudio
