Keyboard speaker project - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 11th July 2005, 01:50 AM   #11
Brion55 is offline Brion55  United States
Send a message via Yahoo to Brion55
No, the 6.5" drivers wouldn't be up to the task if he were using only one, but as I understand, he is using 4 per cabinet. That is slightly more displacement than a 12" speaker.
How do I put the smoke back in this thing?
Old 11th July 2005, 09:28 AM   #12
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Yes, that's right - FOUR per side, so a total of EIGHT.
I did actually write a pretty long reply last night but my home Internet connection stopped working before I could post it.
I did some rough calculations, and 4 x 6.5" drivers provide a surface area approaching one 15" driver. So EIGHT would be outgunning a 15" on surface area by a good margin. Furthermore, when four voice coils disperse the power rather than one our thermal power handling should be pretty good. These drivers were used in mini-subwoofers, so they should be capable of taking a beating. And what's more, if they broke they can easily be replaced.. I have loads. Also, if you'll compare to a 15" PA driver, these will likely have a smoother midrange (I've heard it and it's pretty smooth) whereas your 15" will have a ragged midrange and short xmax.
I did say in my attempted reply that this project is becoming more and more likely to be used in practice and less likely to be used on stage, so maximum output may not be quite such a huge issue. I certainly feel an accurate sounding setup will be most useful to him in practice.
I heard my brother Mark's band for the first time last night, and they weren't too bad It's given me motivation to get going with this project
Old 11th July 2005, 10:27 PM   #13
I was assuming multiple small drivers, but the bass response and power handling is likely to be relatively small - as is the actual volume of sound they produce.
I don't know if you've ever seen the old Bose speakers?, they used to use 8 drivers of about 6.5 inches - they were commonly used for vocal PA. But the small size meant the bass response was pretty pathetic, even though they were PA drivers.
You didn't mention what sort of drivers they are?, are they for home audio?, or car audio? - 6.5 inch doesn't sound much of a sub-woofer?.
Nigel Goodwin
Korg PA2X Pro 76 Key Arranger Keyboard, Yamaha Motif XS8 88-Key Keyboard holocoast Vendor's Bazaar 0 22nd August 2009 08:02 AM
Ideas for a "keyboard speaker" ChrisA Multi-Way 9 13th June 2009 12:37 AM
555 Keyboard Growf911 Instruments and Amps 24 25th March 2009 06:39 AM
Cab and Speaker recommendations for Keyboard amplifier keiichi189 Multi-Way 1 15th February 2009 03:50 AM
Speaker Advice for Keyboard Amp DummannArt Instruments and Amps 5 21st April 2008 10:48 AM
Copyright 1999-2017 diyAudio
