| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 |
diyAudio Editor
More fundamentally though, I meant the difference between a musical instrument speaker that creates a particular sound vs. a PA type speaker that is supposedly just reproducing the signal as it is.
#12 |
I think the speaker should be clean and neutral up to as loud as you want to go. Use your preamp/pedal/effects rack for making it sound nice. Design it as a PA speaker; this leaves you the option of running vocals or backing thru it if the mood takes you.
If you start with a 'guitar' speaker it might sound nice for woody blues, but you'll never get sparkling highs or a natural acustic tone.
I w isH i cuold typpe bettr |
#13 |
Thanks to all for the comments.
What does one get if one builds a cabinet designed around the thiel-small parameters for one of the popular (Eminence, Celestion, etc.) "guitar" drivers? PA speaker-esqe? Does a simple open-back cabinet have little to no impact on the sound? It seems relatively straight forward to read the claimed tonal quality of these guitar drivers and make a decision based on that. But none of them recommend a cabinet (unless you follow the PA route.) Further Comments? Cheers. |
#14 | |
Rodolfo |
#15 |
Are there guidelines for the dimensions of an open-back driver enclosure?
#16 |
diyAudio Editor
Yes, but I can't find the chart. I'm sure someone will post it.
It may be smaller than you think for a guitar. Edit: actually it probably won't surprise you at all- it will probably be the size of say a Fender twin.... |
| diy piezo for acoustic guitar | eketehe | Instruments and Amps | 0 | 26th May 2009 09:02 AM |
| Acoustic guitar amp | pojk | Instruments and Amps | 13 | 7th January 2009 02:28 PM |
| Page generated in 0.09978 seconds (73.25% PHP - 26.75% MySQL) with 10 queries |
