Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 20th January 2005, 11:04 AM   #11
bjorge is offline bjorge  Norway
It would be advantageous to run the circuit off a Mains supply. Those Inverter-based circuits are really sensitive to battery voltage. Quite understandable, as the non-linear point sets in at a certain level below V+ (positive amplitude) and above 0V (negative amplitude). I built such a circuit with adjustable voltage - and there was only one usable setting for the supply voltage, AFAIK. A volt below this - and the thing sounded like ****.
I also seem to remember that those circuits should be built using an even number of inverters in the signal path, as distortion is not symmetrical. After 2, 4 or 6 inverting stages it's evened out.
Regards, Bjørge
Old 28th January 2005, 12:46 PM   #12
gr8idea is offline gr8idea  United States
Here's a site that has a lot different guitar distortion schematics, although some links are broken.
http://www.geofex.com/schemata.htm
Old 21st February 2005, 02:59 AM   #13
Ahab is offline Ahab  Sweden
If you wanna go ultrasimple, check this out:
http://home-wrecker.com/bazz.html
Much modding to be done. I put 2 in series, added some pots and changed some R and C values around.. grat fun and good overdrive to fuzz sounds
/Johan
Old 22nd February 2005, 04:09 PM   #14
www.diystompboxes.com
Many distortion schematics out there
Check
www.runnoffgroove.com
www.tonepad.com
www.generalguitargadgets.com
home-wrecker.com
fuzzcentral.tripod.com
www.moosapotamus.com
www.smallbearelec.com
Old 22nd February 2005, 06:04 PM   #15
elmer is offline elmer  Philippines
Default easy distortion project
good day!
try http://www.j.philpott.com/effectronics/ this site will guide you for building a distortion.
actually, the schematic does work, the fact that i made one.
good luck!
ultra-low distortion audio oscillator geekysuavo Analog Line Level 14 8th September 2011 10:51 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
Ultra low distortion amp eicen Analog Line Level 10 26th February 2008 01:02 AM
What effect does a TL have on harmonic distortion? owdi Multi-Way 0 26th April 2006 03:55 PM
tube distortion effect. jim Tubes / Valves 7 5th March 2005 07:57 AM
Page generated in 0.07424 seconds (80.23% PHP - 19.77% MySQL) with 11 queries
