Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 6th January 2005, 08:23 PM   #11
Ok guys, I ordered all the parts from mouser. they should get here soon.
While I knew the values, I had no idea what variety of capacitor I should use... they were so cheap that I got a ton of different values and materials... ceramic, film, polyester, etc. I'll try to create a setup where I can easily interchange the caps to see if there's any difference in the sound output.
I'll let you guys know when the parts arrive.
Old 11th January 2005, 05:12 PM   #12
Alright, the stuff is here!
How in the world do you wire a circuit up to such a tiny microchip??? This thing is like 1/4" by 1/2" and it has 14 pins coming out of it! Can you just use a regular soldering iron?
Guess I'll get to work on my accuracy. I would just worry that it would be really easy to fry the chip.
Any advice? thanks.
max
Old 11th January 2005, 11:41 PM   #13
raypsi is offline raypsi  United States
Default get out that 100W iron j/k
A temp controlled solder station would be a good start, some can be had for dirt cheap prices. A micro fine tip of say 1/16" either conical or screwdriver shape. A straight iron of 30 watts is good. With inter-changeable tips are the boss. Make sure you tin the tip before it gets to hot, on first time running. A swing o lamp with a magnifier built in is a must.
I like using ic sockets for prototypes. As for soldering: the IC generally can take an iron tip on a single pin for 10 seconds. Any longer than that you are going to be living on the edge.
63/37 solder is the best, 60/40 is acceptable and solder must be resin core.
Lastly, soldering is a fine art. you'll love tacking on little SMD's.
semper fi
Old 13th January 2005, 05:09 AM   #14
Enzo is offline Enzo  United States
If you have never soldered on a pc board before, consider building a simple kit first to get some practice. There are many small simple kits involving a chip or two. SOme blink lights and others make noises, but for a few dollars you can get something and get some practice doing the work. That is better than damaging your real project.
Old 16th January 2005, 02:29 PM   #15
BbbyBld is offline BbbyBld  United States
They are kind of noisy, but I might build on a breadboard first. If you plan on experimenting regularly, you should probably get one. The first kit you build could be a variable power supply--you will need one of those too.
Sub project ideas greg_mcquaid Subwoofers 7 13th January 2008 03:35 PM
New amp project-some ideas of my own and looking for input from others... mr mojo Tubes / Valves 8 25th September 2005 04:19 PM
My first DIY project with some kef sp1022, any ideas? VvvvvV Multi-Way 16 28th October 2004 03:54 AM
I Need More Ideas On The Project Problem jaramke Solid State 1 17th August 2003 12:31 PM
cheap project ideas theChris Parts 0 22nd March 2003 02:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
