Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 19th November 2004, 02:46 PM   #1
Default To Match Impedance on DI Box, or Not to match?
Hello everybody! I'm trying to build a passive DI box, but I need to clear some things up first. So here's my plan: guitar line goes into a step-down transformer, into a mic pre. Simple enough? But what input impedance do I need on the transformer? I know for an op amp, or a transistor, I would want the highest impedance possible, as these don't need the voltage transfer, so much as current. But what about a Xformer? Wouldn't I want it to match the guitar so I could get the maximum voltage transfer? But I've seen a lot of people recommend a 200K input impedance, which is way up there! Wouldn't this give me a thin, trebly sound? But if I match them, I'll lose half my guitar signal! I already ordered the transformer when I thought I had to match them, it's 65K. But this can be adjusted, sort of, by running a pot in series or parallel with it to change what the resistance looks like to the guitar. But I saw a list of different pickup specs and their impedances at various frequencies change drastically! Like 8K for low frequencies, 80K for high frequencies! So if I do match them, or not, which of these frequencies do I consider the "guitar impedance? As you can see, I'm pretty confused, and the time has come to ask for some guidance. So could somebody please tell me what the input impedance should really be on a DI, and why?
Thanks!!
Old 21st November 2004, 10:09 AM   #2
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
You MUST have an input impedance of at least 1Meg, or you'll lose all the top end of the guitar! But, my friend, why to use a passive DI? Stick with a FET, a pair of resistors and you're done... You can also mount it into the guitar body! So you can use extra long cables, you can plug directly into whatever you find, etc... It's very useful.
I don't think I've ever seen a passive DI for the guitar... It can be useful for mics, where you need to raise the impedance... But here you want to lower it!
How much mis-match can an OT take? bereanbill Tubes / Valves 6 10th May 2009 01:40 PM
Need help with Output Impedance match. Learn the lesson from me!!! SE_ClassA Digital Source 16 16th July 2006 08:42 PM
Speakers to match GC?? monkey_zu Solid State 0 20th September 2004 05:08 AM
increasing o/p impedance to match IT?? AudioGeek Tubes / Valves 3 10th July 2004 07:15 PM
How to match the FET TjongKristian Pass Labs 2 6th September 2002 05:57 PM
Page generated in 0.09222 seconds (72.21% PHP - 27.79% MySQL) with 10 queries
