| Instruments and Amps Everything that makes music, Especially including instrument amps. |
I'm just curious if someone has tried this and how it turned out. I am also intrested to find out it anyone has moded any mixers for DJ use.
http://www.caraudioconnoisseur.com/ |
#2 |
bump
#3 |
Unless you just wanted a project to do, it would seem like it would be a lot easier to just buy a DJ mixer. Used ones are not expensive, and depending on your needs even new ones can be reasonable. Even Radio Shack has a couple on the rack. I think they wanted like $99 for one I saw yesterday.
You can buy more expensive ones like the Rane, and Pioneer makes a couple nice ones. But the basic Numark, Audio Technica, Gemini, MTX and others work for thousands of DJs. I also work with DJs who use plain old PA mixers and use the PFL for cue or an AUX send. DJ mixers still usually include phono preamps in case you need them. And the crossfader is much of what makes a DJ mixer different. PA mixers have no phono preamp and no crossfader. If you don't use any vinyl, you don't need the phono preamp. What is your need here? |
#4 |
I am looking for something that could compeate with the Bozak and allen & heath V6 in sound quality without costing the $1500 or $4000.
#5 |
I must admit my ignorance. I was not aware that A&H or Bozak made DJ mixers either one. What capabilities do you need for your system? NUmber and types of inputs, types of outputs, crossfader? Assignable Xfader?Ducking? Effects?
#6 |
Those new Xone units from A&H are going to be hard to duplicate for the street prices I've been seeing.
:)ensen.
Those who claim to be making history are often the same ones repeating it. |
#7 |
my friends A&H Xone X2 is by far the best 3ch mixer ive ever used..
any ideas how they implement their filters? the levels and everything sound so perfect every time which made me wonder if its a dsp doing it? as far as building my own dj mixers would go.. ive thought about it, and even have an old phonic 5ch mixer which ive gutted out. i was thinking of building high end stuff inside using the old faders and repainting it all.. still might one day but it would be a lot of work, and im not sure the results would be worth it for the time spent.. i could build a synth instead or something |
#8 |
I wouldn't recommend building one yourself. Getting close to the quality of an A&H would be a damn hard job. For the quality wat is reasonable to reach you'd better just buy one, cause building one yourself won't cost you much less, but will take ages. Check some of the new Numark or Pioneer (i wouldn't recommend Gemini to be hounest) products, they're excellent for the average DJ. Remember, als long as the rest of you're set-up isn't the best of the best, even the best mixer in the world won't change much...
#9 | |
Most mixers use cheap opamps like 4558/4559 with a single powerrail so a TL07x or NE5532 and double powerrails give a good boost in sonicquality. Also, the headroom is usually too low so lowering the gain on the inputs and raising it again at the final output will lower the distortionlevel. |
#10 |
Can you give a walk through on this, pictures, more details?
| have anyone make th HIGH QUALITY AUDIO MIXER | darkwind_j | Solid State | 1 | 29th July 2009 03:59 PM |
| have anyone make th HIGH QUALITY AUDIO MIXER | darkwind_j | Parts | 0 | 28th July 2009 02:58 PM |
| anyone ever built a tube mixer similar to the RCA Living Stereo type?? | ncdrawl | Tubes / Valves | 12 | 23rd October 2008 07:13 PM |
| Question about power amp built in high pass filter | crippledchicken | Solid State | 0 | 22nd October 2008 07:09 PM |
| 70's home-built mixer - please help me id missing chips! | ultrajosh | Parts | 10 | 27th November 2005 04:05 AM |
| Page generated in 0.10400 seconds (78.18% PHP - 21.82% MySQL) with 10 queries |
