Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 9th January 2005, 07:07 PM   #11
Originally posted by DJNUBZ
Can you give a walk through on this, pictures, more details?
Sorry, no.
It is a simple operation but if you need a walktrough then it is probably too advanced for you.
All you need to do is to open you mixer and find the OPs and then replace them with better ones.It is quite simple, especially if you find a replacement OP that doesnt need a double set of powerrails.
The gainshift isnt necessary if you are going to use it yourself. But i have a rentalcompany so i must prevent all those stupid djs from overloading the mixer.
What mixer do you have?
Old 13th January 2005, 03:35 PM   #12
Default try finding theese models
Alot of dj mixers are junk.
Try finding a used Rodec or Soundcraft wich have great build quality and are nice overall units.
I also think the A&H units are nise but they are so big...
HH
thanks for reading.
H.Honda Chico CA Land of the fooled
Old 20th January 2005, 12:54 PM   #13
Default Re: try finding theese models
HH
I agree on the fact that most djstuff is junk.
But why are people sayng that rodec is good? I have heard that before, but my experience is that rodec is the worst sounding mixer by far.
I dont like those A&H mixers that i have tried, which only is GL2200,3000,4000 and similar PA mixers, not djstuff.
But other good djmixers that i have repaired are Ecler and formulasound.
Old 30th January 2005, 12:59 AM   #14
Kinda starting the process of doing so. Reason? Most DJ mixers available at present are either; utter **** in terms of reliability, far too complicated(too many same colour little knobs for functions more fashionable than needed - typical bells & whistles syndrome), or far too damned expensive and large. Add to that the fact don't implement PFL or Send/Return in any standard way, along with the poor quality audio <sigh>
I've seen inside and repaired far too many 'big name' makes of moxers and other audio kit to be impressed by anyof todays offerings that are reasonably affordable - and how the same "big names" get away with charging what they do for spare parts! Most crossfaders I've seen contain an active part which costs pennies (at the most a uk pound a piece) from from normal component suppliers. Even those much-admired Penny & Giles things on the rails etc etc are only about fifteen uk pounds each! Channel faders cost at the most only 5 uk pounds each for top range types - DJ mixers use the ones that cost pennies. Input switches - max cost of the types usually fitted - again it's pennies. And they charge what - ukp 45 upwards for a fader, ukp 25 upwards for a switch?
I'm planning a very modular approach, using voltage control for faders and crossfader (keeps audio signal away from noise-inducing compenents - and allows use of more reliable mono, rather than stereo. faders. Any components that actually carry audio (ie gain trim pots) will get top quality parts. I want serious reliability along with decent audio quality.
There'll be LOTS more metering and on a "metering bridge" above main mixer panel and angled so eaily visible - with both led-type (dimmable) plus big analog meters too, so levels of both channels & master output are always displayed. All metering in dBs Option to use VU & PPM metering. Plus BIG bright "Signal Clip" leds visually SHOUTING and impossible to ignore - for that all-to-common "DJ-now-deaf-so-can't-hear-distortion-now-clearing-main-dancefloor" scenario.
Balanced audio I/O. EQs external (allows use of simple kills, complex parametrics, whatever's needed.) Inputs will be line-level only - phono preamps to be seperate modules close to record decks.
Panel layout uncluttered. Legends simple & very clear with colour/shape/pictograms legends instead of written words where poss (Pic of headphones, not word ""headphones", swirl getting larger around a knob to show "more" rather than tiny numbers illegible in dark places (ie DJ booths).
Good contrast between inportant controls and panel (no more black on black or pale on pale illegible knob-fields!) Important controls larger than rarely-used controls (ie "Master Out" level knob larger than individual channel gain trim knobs. "Channel PFL" switch larger and different from "Channel Send" Switch. Channel "Balance" control not positioned so as to be mistaken for an EQ or Trim control.
Still working out the overall structure/block diagram - ie what buses/audio signal/control signals are needed. DJ mixers don't usually have enough routing & studio mixers have too much for DJ needs! None of the circuitry needed is rocket-science these days. No esoteric or even very expensive parts needed. The hardest bit to make is probably the front panel metalwork (esp the slots for the faders.)
Xfader will be contact-less - no parts in contact, nothing wears out so everlasting xfader and no crackly probs ever. This is partner's current project. He's still building prototypes and involved in the black-arts of magnetism, coils-of-wire, coil-winding machine, bits of old ferriteetc. Very good so far - scope traces look excellent. Have to perfect DJ-abuse-proof mechanics for same :-)
tekno.mage
Old 15th March 2005, 08:04 PM   #15
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Send a message via Skype™ to VEC7OR
How is the progress on your friends project ?
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
have anyone make th HIGH QUALITY AUDIO MIXER darkwind_j Solid State 1 29th July 2009 02:59 PM
have anyone make th HIGH QUALITY AUDIO MIXER darkwind_j Parts 0 28th July 2009 01:58 PM
anyone ever built a tube mixer similar to the RCA Living Stereo type?? ncdrawl Tubes / Valves 12 23rd October 2008 06:13 PM
Question about power amp built in high pass filter crippledchicken Solid State 0 22nd October 2008 06:09 PM
70's home-built mixer - please help me id missing chips! ultrajosh Parts 10 27th November 2005 03:05 AM
Page generated in 0.10279 seconds (81.28% PHP - 18.72% MySQL) with 10 queries
