diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-and-amps/)
-   -   15" speaker for a bass cabinet (http://www.diyaudio.com/forums/instruments-and-amps/40157-15-quot-speaker-bass-cabinet.html)
Zaireeka 29th August 2004 02:11 PM
Hi everybody, I'm a bass player and I'm planning to build a bass cabinet of 100-140 liters with a 15" driver.
The idea came after reading this page (http://www.geocities.com/SunsetStrip...1/speaker.html), and also because I can't afford a "real" bass cabinet !!
Now I have to choose a good speaker to motorize it. I'd like to have a frequency response going down to 40Hz (the lower note on a 4-string bass is the E, at 41Hz) and also a good power handling (up to 300W).
That's why I think using a "sono" driver rather than a specific Peavy, Eminence or Celestion bass model.
Maybe the B&C 15 TBX 40, with its low Fs and high Xmax (38Hz and 9mm) http://www.bcspeakers.com/compproduc...rs/15tbx40.htm
Is this choice reasonable or must I use a "true" bass-designed driver ?
Can someone recommand me a good driver if the B&C isn't a right choice ?
Thank you.
Resources saved on this page: MySQL 18.75%
