| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 |
also..
a pair of questions about your schematic: -are the transistors critical for th eeffect? or can i use any general purpose PNP?? ( i've read somewhere that i can place a NPN instead of a PNP if i switch all polarities... that means i could use the 3904's right?) -why the 4.7uF capacitor appears as non-polar?? is it that way? -where are both pots?? -now about the original effect ( and yours)... why is there a 100k resistor at the very beggining? ..i know you said it is there to create a voltage divider.. now, am i suppossed to hear the original audio signal when the circuit is not voltage feeded? thanks again cya!! |
#12 |
about the caps...
what are their specific polarities? (if there are any) ..by the way.. i assembled your version of the circuit.. and the only thing i get is a pulsating noise through the audio signal ( this when i switch the 100k res for a 220ohm res) ...damn, i want it to work... |
#13 |
Hi, don't worrie, I think you might have overlooked something. It's a simple circuit and it will work.... gonna read you posts now and get back later... cya,
Thijs |
#14 | ||||||
39K / 100K+39K or 3.6 times.. about 11dB When the second transistor is not driven but is 'OFF' , the signal get through the 100K, but doesn't get attenuated through the 39K... so it cycles through attenated/not attenuated.. just the effect we are looking for.. When the whole circuit is left without a voltage suypply, you should here the original signal, since the second transistor cann't be driven 'ON'.. it might be a weaker signal because of the 100K that's allways there.. that's why I used a high impedance buffer... Quote:
goodluck.. |
#15 | |
In the original version (using NPNs and a +9V supply) this cap should be flipped around... |
#16 |
it's alive!!!
man, first of all, i want to THANK you for being so patient to explain me every detail of this thing..... for giving me strength, and even for having make an alternate version of it well, bet you couldn't guess were was located the problem... it was external it was the defficient audio probe i set up for testing purposes.... the out impedance was insufficient, so i could not hear anything, even when the circuit was running perfectly fixed that and NOW i can hear the audio tremulating and stuff after some tweaks ( like reversing that polar cap, or altering the value of the 39k filter stage), the tremolo can variate from a very subtle oscillation to a very deep alteration of the original source, to a chopper-like effect, which is cool as hell!! thanks a lot, i really appreciate your kind efforts i've learnt a lot and now i want to do more effects thanks for everything, cya!! |
#17 |
no problem, I'm glad I could help.. You're right about the modulation depth: best to controll it by using a 47K ..100K? potmeter instead of the 39K resistor... Mine works pretty good also.. allthough it picks up a lot of hum... have fun.. come back with some other guitarFX if you want...Cheers, Thijs |
| Tube Amp reverb noise, no vibrato intensity, unknown model. Help please | tedsorvino | Tubes / Valves | 0 | 11th March 2008 10:21 AM |
| Fender Twin Reverb VIBRATO PROBLEM - weak vibrato | gibsonripper | Tubes / Valves | 2 | 19th January 2008 04:23 AM |
| hey i need a little help with this circuit | electro_groove | Car Audio | 3 | 25th February 2006 02:49 PM |
| wavy vibrato-like sound when amp cranked | 9am53 | Tubes / Valves | 4 | 19th May 2005 12:23 AM |
| Trouble with speaker protection circuit (Randy Slone's circuit) | whalefat | Solid State | 3 | 13th April 2005 10:13 AM |
