| Instruments and Amps Everything that makes music, Especially including instrument amps. |
hi men
I still need help about my project since I'm going to pit it into reality. is this gonna sound good?? how to enhance this? any suggestions welcome... |
#2 |
...........think this needs to go back to drawing board...
As there is no closed DC path through this circuit, the output of the first opamp will latch to one of the supply rails and won't function. The output will have a large DC offset and probably draw large amounts of current. Are you trying to convert a tube push-pull to solid state?? Cheers |
#3 |
yeah centauri
you've got the point here... d'you think putting 100k resistors in paralel to caps will solve this problem ??? help needed cheers |
#4 |
hi, i've built the 100W amp from elliot sound product
but i'm using my own PCB design. the problem is that the output from the power amp circuit tend to draw a large amounts of current. can you help solve this problem or do you know someone that expert in this field. i've attached the layout of the PCB in the attachment. can you give me your e-mail address. my e-mail address is sovtek_svetlana@yahoo.com. another thing, what is meant by closed DC path? |
#5 |
I don't know exactly how to help you, but I know that there are several guys at ssguitar.com that should be able to help with your problem pretty easy.
Life is what you make it. http://www.ssguitar.com |
#6 |
first off i think the minus input of the 1st op amp should not connect to the speaker outs. 2nd the input impedance is too low for guitar the 22k to grd s/b 100k to prevent loading the pickups.
i would use a quad op amp and the first stage would be a buffer. 3rd you have no tone or gain controls . install a duel 10 to 100k pot in the feedback loop of the 2nd stages replacing the 4k7 resistors. this will give some gain control. |
#7 |
Why don't you use a pnp on lower driver?
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
| Solid state guitar amp. help needed! | pilt | Solid State | 8 | 17th April 2011 06:25 AM |
| Solid State Guitar amps worthwhile?? | AuroraB | Instruments and Amps | 113 | 4th June 2010 01:32 AM |
| Solid state guitar amp | Itbmetal | Instruments and Amps | 8 | 18th May 2009 04:13 PM |
| Solid State Guitar Amp Books | Trepan | Instruments and Amps | 2 | 22nd May 2007 04:26 PM |
| Solid state guitar amp | bostjancek | Solid State | 9 | 16th August 2003 06:23 AM |
| Page generated in 0.09222 seconds (76.96% PHP - 23.04% MySQL) with 11 queries |
