diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-and-amps/)
-   -   Building Marshall Plexi (http://www.diyaudio.com/forums/instruments-and-amps/36321-building-marshall-plexi.html)
zxx123 19th June 2004 01:40 PM
I have built plexi, however, I cannot find any
information about their B+ VOLTAGE in preamp part.
Especially, how much volt each three stage after
(or before) 100k plate resistor?
The reason that I ask is that I use different power amp part.
I need to modify it.
http://www1.korksoft.com/~schem/mars...1987_plexi.pdf
Gilessteve 19th June 2004 03:01 PM
B+ voltages in older Marshalls are the subject of endless discussion. My understanding is that the voltages varied from year to year, and also between individual examples. Marshall are notorious for using whatever parts were available in a pinch in the early days.
Some older Marshalls have been reported to have very high B+ supplies. I've seen vintage amps (Marshall inspired designs) where the B+ was in excess of 600v (measured at the power amp stage).
Try re-posting the question on the Plexi Palace forum. There are several knowlegable people there who'll surely be able to give you a more definitive answer. Also see the older threads.
Steve
Resources saved on this page: MySQL 18.75%
