Valves for Crackly Fender Hot Rod - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th May 2004, 12:46 PM   #1
Default Valves for Crackly Fender Hot Rod
I've got a Fender Hot Rod Deluxe 40W (guitar amp), which I'm not really using at the moment, but it's been a bit crackly for a while. The actual sound of the guitar is fine, it's just hissing and crackling quietly in the background. I assume this means time for new valves, am I correct? If so, is it the preamp or poweramp valves I have to change, or both? I think there are 4 12AX7's in the preamp and 2 6L6's in the poweramp. How much will this cost? Also, as I don't use the overdrive channel much, is there a way of making this into another clean channel?
Jonny
Old 18th May 2004, 12:55 PM   #2
316a is offline 316a  England
316a's Avatar
Default Valves
Hello ,
Pity you're not near London , otherwise you could have brought the amp to me and I could have tested the valves for you . Have you reseated the valves in their sockets yet ? Otherwise it could be noisy pots that could be the problem . If you think the 6L6 are past their prime I think I have a few sets of Sovtek 5881 kicking around that need a good home
cheers
316a
Old 19th May 2004, 06:01 PM   #3
Wow that's nice of you! I'll try the things you said and if they don't work, I'll get in conact with you about those Sovteks!
Jonny
Valves Professor smith Pass Labs 47 10th June 2009 10:58 PM
Which valves for MF CD-T paultb10 Tubes / Valves 1 7th October 2007 04:42 PM
First amp for a new in valves JORGETronic Tubes / Valves 2 12th June 2006 01:38 AM
WW2 valves exurbia Swap Meet 0 20th September 2003 09:19 AM
813 valves slowmotion Tubes / Valves 36 27th January 2003 11:54 PM
Copyright 1999-2017 diyAudio
