Mashall Lead 100 Mosfet -> bad sound - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 11th May 2004, 01:48 PM   #1
Flo1K is offline Flo1K  Germany
Default Mashall Lead 100 Mosfet -> bad sound
Hi! im new and home u can halp me.
I got a Marshall lead 100 Mosfet for a few bucks but the sound is very unclean even in the clean channel.
The problem must be in the last stage power amp cause the sound of the DI is ok.
here is a shematic of the stage:
i dont know how to find the problem so im happy is u post some tips for me to fix it.
thx
newb Flo
Old 11th May 2004, 01:55 PM   #2
jan.didden's Avatar
Pray tell, what is a 'DI'?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 11th May 2004, 01:58 PM   #3
its the direct output of the preamp (for mixer in for example).
here is the complete shematic http://flosen1000.zapto.org/Mar_3210.gif
Old 11th May 2004, 02:54 PM   #4
Is the speaker (s?) possibly blown ?
Old 11th May 2004, 03:08 PM   #5
jan.didden's Avatar
Can you do some simple measurements, like DC supply voltage, DC at the speaker output? Compared with the 'good' channel. If you say the sound is unclean, what exactly do you mean?
Jan Didden
Old 11th May 2004, 04:00 PM   #6
ok, voltages and speaker are ok.
hmm the sound is muddy dont know how to explain .. sometime the level goes totaly down and after a while it comes up again ...
Old 18th May 2004, 08:11 PM   #7
rljones is offline rljones  United States
There may be a short circuit and the current limiters are activated (TR10/11). Or, possibly a bad cap in feedback loop.
If there is definitely no short circuit on the output, you could temporarily remove TR10/11 from circuit (lift one leg of D10/11) and see if this helps. (These things would be better checked on a test bench, but if you must connect a speaker for testing, use one you won't might destroying.)
If there is a short circuit at the ouput and TR10/11 are activated, the heatsink for the outptu devices should get rather warm soon after powering up the unit. But if the devices are misbehaving, they can create a distorted output.
Marshall Mosfet LEAD 3210 blowing power fuses - help locating capacitor(s) jmilch Instruments and Amps 13 20th August 2009 05:31 AM
Elliott Sound MOSFET Power Amplifier rmihai Solid State 35 20th September 2005 03:10 PM
lead vs sand IZHAKKATZ Analogue Source 15 4th November 2004 04:21 PM
Copyright 1999-2017 diyAudio
