Help with 2 pickups loose wire! - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st September 2015, 11:46 PM   #1
oszkar is offline oszkar  Romania
Default Help with 2 pickups loose wire!
Hello!
I ran over an electric guitar that I had to dismantle only for cleaning because it is going further as a memory accesory to someone!
In the process one wire came loose due to my clumsy hands and I do not know where this wire goes!
A little history uppon the thing:
- I suppose since in the pickguard is a supplementary hole, there was a pickup comuter that went broke on functionality and it was remowed, with wires soldered on tzo it beeing soldered afterwards on another functional point in the guitar!
Pics are atached, please tell me where to solder the wire that went from Potmeter to loose
Thak you!
Old 21st September 2015, 11:47 PM   #2
Here are the pics:
Old 22nd September 2015, 03:31 AM   #3
It's probably the earth wire from the bridge, solder it to the earth connection on the pot
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 22nd September 2015, 04:41 PM   #4
Did that! Well tomorow I am for a better practice I am going to get all the stuff but the pickups new to put it in a better ready to play condition up for use! To be better understood what is happening over here I am posting a picture of what was going on! I will get 2 x 100k potts, 2 volume pots covers to mach the guitar, 2 on / off switches with 6 leggs! I will still use the 0.047uf cap! Could anyone provide me with a wiring schematic, I am posting a pic that depicts quite everything as in mater of components this one has in it! please tell me where to corect! Thank you!
Old 22nd September 2015, 04:48 PM   #5
Here is how it looks after deep cleaning, more restoration is not coming onto it as it has sentimental value! Here is the diagram I found!
Old 23rd September 2015, 07:58 AM   #6
Here are the components that I have got and the strings are comming tomorow! Anyone, pls help, I do not understand the whole serries and ground for this project! Lets start with: (Pot. 1) + (Pickup 1) + (Switch 1) and I suppose (Output jack). I have for now Black + Green wire, thin copper wire and some gray I think I am going to search a little bit and I am coming back uppon the subject!
Old 23rd September 2015, 09:24 AM   #7
Here is something I croped out!
Optical Pickups travis Instruments and Amps 6 20th June 2014 11:22 PM
Piezo pickups Pbassred Instruments and Amps 17 19th April 2008 04:56 PM
magnet+coil pickups, piezo pickups and Roland GK-2 midi, how does the output differ? Puggie Instruments and Amps 1 19th September 2006 07:51 PM
Rewinding Pickups DolbyR Instruments and Amps 3 31st July 2006 10:50 AM
optical pickups hacknet Instruments and Amps 11 15th November 2004 06:22 AM
Copyright 1999-2017 diyAudio
