Biyang WANG AMPS VT-1H mini guitar amp - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th June 2015, 08:26 PM   #1
Default Biyang WANG AMPS VT-1H mini guitar amp
The first brand new guitar amplifier I've ever bought "new" instead of built or repaired! Also my first Chinese amp...LOL! Hand-wired by a family operation.
Really cute circuit:
Most mini-amps are single-ended in the belief they are simpler, but end up inefficient and require a large power supply, filters, and heavy output transformer. They tend to model after the classic Champ.
This takes a different push/pull route. All tubes are dual triode preamp tubes, which actually work acceptably as output tubes when used in push/pull.
The first stage has both halves of a high-gain dual-triode in parallel.
Then there is a one-knob tone control, with the counter-clockwise "bass" setting shunting the pre-volume (right after the coupling cap from the previous plate) treble to ground via a cap, and the clockwise "treble" shunting the treble across the volume pot, like a variable "bright" switch. Not much gain loss.
Then the first side of the second high-gain preamp tube gives gain. The second half of that tube is a paraphase phase inverter.
Then the two halves of a moderate-gain higher-current dual triode are used as the push and pull output stages. Each stage pushes into a half of a 10K - 0 -10K primary on the small output transformer, with a single secondary labeled "8 to 16 ohms."
This is the smallest 3-tube push/pull I've ever seen. I'm still waiting for it to arrive. Judging from the YouTube clips, this thing is killer.
I guess it also shows that Chinese tubes are cheaper in China than Chinese transformers! Otherwise you could build a nice little 2-tube push/pull amp using an interstage transformer as the phase inverter.
Old 26th June 2015, 08:28 PM   #2
Yes, I know smaller tubes exist...
Old 26th June 2015, 08:30 PM   #3
WIMA caps, metal-foil resistors, fiberglass PCB, ceramic tube sockets.
Old 3rd July 2015, 10:53 AM   #4
Search for Hghes Kettner Tubemeister 5. Push-pull triode output stage 5W, one preamp tube. Definately better than this Chinese amp.
Old 3rd July 2015, 12:57 PM   #5
Of course the H&K is better. It's normally three times the price too. The big box retailers right now have $200 off the H&K, otherwise it's $169 for the Wang vs. $499 for the H&K. Not comparing apples to apples.
Old 3rd July 2015, 01:53 PM   #6
I'm a bit intrigued by Rob Robinette's micro amps that use triode power amps, like the micro-Bassman.
I'm not at home, and I can't remember the tubes, but I got a lot off eBay that included some high current triodes that I think are normally used for triode power amps. At some point (after I complete my 4 or so pending projects) I'd like to do something with those.
Old 3rd July 2015, 02:17 PM   #7
Great reference, pdavis. He has a great site for mods and ideas. Got his site in my favorites. This amp you provided the link to is more in the category of the Wang
Old 3rd July 2015, 02:25 PM   #8
I just happen to have been perusing his mods last night and I've had the micro-Champ and micro-Bassman in the back of my mind since I got those triodes. It looks like the Wang is OTL. I don't have a good handle on how to do those. I'd love to see a schematic. All the examples I've seen of OTL amps use 500-800ohm speakers.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 3rd July 2015, 05:40 PM   #9
Bone is offline Bone  United Kingdom
Output transformer is inside the case mounted on the main PCB.
Old 3rd July 2015, 06:30 PM   #10
AudioFreak88's Avatar
if its any of those WIMA Box/metalized I would be ripping them out....
Guitar Mini Amp with PAM8610 Module mnesarco Class D 5 14th April 2015 09:24 PM
12 volt /5 amps off mains vs 12 volts/3 amps off battery power for mini-amp? Jaxhouse Power Supplies 3 20th June 2014 11:44 AM
I have a design decision to make - mini guitar amps KFW Instruments and Amps 2 10th October 2012 09:52 PM
Mini guitar amp from a Webcor tape amp, is it possible? StiffHand Tubes / Valves 9 28th July 2006 01:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
