New JFET guitar preamp project - Page 13 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 28th June 2008, 11:20 AM   #121
Nordic is offline Nordic  South Africa
Nordic's Avatar
JP you don't maybe have two of those fets for me? The only place I can source them here they are $2 each and I need to buy a minimum of 10, which is tight for a pensioner...
I am haveing a horrible three days... now on 3rd rebuild of a MXR dynacomp pedal... each with varying degrees of failure
Just came back from the printing shop with some press and peel for a third and final attempt... this time I went for 1.3mm traces and 1.3mm isolation... should be a bit more DIY friendly... there is quite a diffirence in designing a board for home etching and soldering and one that would come masked from a factory.
Old 4th July 2008, 08:20 PM   #122
Thank you Mr. Hugsley. Now I think I've got all I need to know to design and build what I want.
Wish I still had my O-Scope though. Sure would simplify things. But I sure this will work just fine.
Thanks again,
Ken
Old 24th July 2008, 01:01 PM   #123
maniax is offline maniax  Indonesia
Hi can u help me???? please....
Please send me an e-mail at maniaxwanita@yahoo.com including the Jfet guitar preamp schematic of the page
www.bossaboa.dk/preamp.gif
because I donīt open this page from my home
Thank you very much
Old 24th July 2008, 03:00 PM   #124
That site is closed, apparently. I get a "server does not exist" error message.
But if you want a nice FET preamp, this very thread has the best one I have found online, and I've done a LOT of searching. Plus it has a complete description of construction and the theory behind it as well.
Ken
Old 24th July 2008, 07:04 PM   #125
Default Re: Updated schematic for FET guitar preamp.....
Originally posted by jazzpeter65
Updated schematic for FET guitar preamp:
I've made a few adjustments and eratas since the first version.
This preamp sounds great - forget about opamps for a moment a try this one. It's warm, smooth and tubey. Very simple circuit with few phase invertion stages.
The thread is quite interesting but I wonder which of the preamps were actually build and work correctly. In the schematic provided by Peter there is a mistake that will cause that the tone controls wont work; resitors R16, R17 and R18 should be connected to the output of U1B (which is how Albert Kreuzer's preamp is designed). Have you noticed this?
I'm looking for a bass guitar preamp (a little bit more advanced than the one by Albert). If you have any ideas, please post them here.
Mark
Old 24th July 2008, 07:18 PM   #126
I also simulated one of the preamps mentioned in the begining of the thread; the Runoffgroove Cabsim. This is typical cabsim and I think that it shouldn't be used as a preamp (especially that it has gain < 1). Attached is frequency response of the cabsim.
Mark
Old 24th July 2008, 11:08 PM   #127
I recommend JP Hugsley's preamp. I've built two of them now and they work Great! There's one in my Strat and I built another for a friend who plays bass. The tone section is easily altered to suit the application and Mr. Hugsley explains exactly how to do it.
Ken
Old 28th July 2008, 06:21 PM   #128
I simulated the preamp. Attached is the frequency plot of the preamp. Looks good but I'm worried about two issues; the gain changes with the frequency and it's x1.8 at low frequencies and x2.5 (and not x6.5 as mentioned in one of previous posts), and other issue it that it's quite difficult to buy J201 (with other transistors I get much lower gain).
But still it looks interesting.
Mark
Old 28th July 2008, 06:30 PM   #129
JP Hugsley, on one of images attached I see that you have a SMD version of the board. I wonder which transistors are used there. Is there a SMD version of J201?
Mark
Old 29th July 2008, 05:58 PM   #130
I found out that SST201 (or MMBFJ201) is a SMD replacement for J201. Also not that easy to purchase.
Marek
JFET preamp? asc Chip Amps 6 10th May 2013 08:21 AM
My JFET project bappe Pass Labs 14 20th June 2012 08:09 PM
Inexpensive JFET Preamp jonusgrumby Solid State 115 28th June 2011 04:46 PM
Yet Another JFET Phono Preamp wrenchone Analogue Source 120 21st January 2011 07:31 PM
Jfet piezo preamp for acoustic guitar frickecello Instruments and Amps 7 22nd May 2009 11:25 PM
Copyright Đ1999-2017 diyAudio
