Help please! 5f1 champ build with No sound! - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 30th May 2015, 09:36 PM   #1
Default Help please! 5f1 champ build with No sound!
Hello all- I recently built a 5f1 clone into a Danish cookie tin- thought it would be a cool project. Turned it on, tubes light up, no smoke, plate voltages are good, and I can clearly see a healthy glow from gas inside the 12ax7 that increases when I change the volume. But- no sound. Yes, I checked the speaker and speaker cable, and the input cable- I clearly must have wired something incorrectly- but I've been troubleshooting for days now and to no avail. Any ideas?! Any help is most appreciated!! Thanks
Tommy
Last edited by theguitaristspeaks; 31st May 2015 at 02:19 AM. Reason: spelling error
Old 30th May 2015, 09:38 PM   #2
kevinkr's Avatar
Moved to appropriate forum
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 30th May 2015, 09:47 PM   #3
kevinkr's Avatar
Detailed pictures of your build and the actual circuit you built to are the minimum required if you want some helpful comments..
Old 30th May 2015, 09:49 PM   #4
There is your problem right there, you shouldn't see anything inside the tube other than the heater glow
Double check your 12ax7 wiring, or post a few pics incase we can spot something wrong...
Old 30th May 2015, 10:07 PM   #5
Thanks for the quick replies!! I'll get pictures up right away. The glow I'm referring to is not red-plating, but a bluish purple glow that I've seen before in healthy tube amps- although I could be mistaken.
Old 30th May 2015, 10:19 PM   #6
Pics of the circuit board and tube sockets on the way one at a time- I can't get it to post several at once.
Old 30th May 2015, 10:25 PM   #7
An overall of the circuit- the previous one was the 12ax7 socket and power switch/indicator (heater wire is twisted red/black)
Old 30th May 2015, 10:27 PM   #8
Rectifier socket left of the board
Old 30th May 2015, 10:30 PM   #9
6V6 socket on the right of the board
Old 30th May 2015, 10:33 PM   #10
A close up of the input jack and volume pot with the 12ax7 socket visible to the left
i have a few questions about 5f1 champ project. Illinest Instruments and Amps 15 23rd June 2014 06:38 AM
CHAMP 5F1 BUILD VOL POT PROBLEM LATUBEGEEK Instruments and Amps 6 4th September 2013 11:43 PM
CHAMP 5F1 BUILD VOL POT PROBLEM LATUBEGEEK Instruments and Amps 0 2nd September 2013 03:51 PM
Fender Champ 5f1 clone squeal Exla13 Instruments and Amps 13 5th August 2013 03:33 PM
5f1 Champ grounding magnetman Tubes / Valves 2 3rd May 2012 09:31 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
