noisy foot switch; is there a fix? - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 10th February 2015, 02:23 AM   #1
Default noisy foot switch; is there a fix?
Hello all, I have been asked to build a simple kill switch for a guitarist friend who wants to be able to silence his guitar downstream of his pedal board so he can silently tune etc... I built a box with 2 jacks connected together (in and out) and a switch that shorts the signal to ground when turned "on". The problem is he complains it makes a click that is audible through his amplifier at the moment he steps on it. No matter if he stomps it hard or gently presses it makes a noise when he turns his guitar "off".
Is this the switch contacts bouncing on connection or what? I do not hear a noticeable click like he does but he swears it is no good the way it is... SO
Is there a better made switch (I used this one: Peavey On/Off Single-Button Replacement Switch) or must he go with an active circuit for a silent kill switch? As a purist guitar type he demands straight through designs (so called true bypass pedal designs only please...) so any design I can think of that would be truly silent would not be true bypass...
Is there another way?
bassmeknik
Old 10th February 2015, 02:43 AM   #2
leadbelly's Avatar
I would try some options in Figure 1:
Mike Mute
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 10th February 2015, 02:54 AM   #3
My design is identical to Fig 1-B (shunt switching). This is what I built. I know better than to use 1-A as that would be an invitation to more noise. I don't understand how using 1-C (both series and shunt switching) would stop the click noise during actuation. Can anyone give an explanation here?
I believe the Figure 1-B diagram as shown is not in the muted position (Fig 1-A and 1-C are in mute position but not 1-B).
bassmeknik
Old 10th February 2015, 03:23 AM   #4
rayma is online now rayma  United States
Originally Posted by bassmeknik View Post
it makes a click. Is this the switch contacts bouncing on connection or what?
Maybe there is some DC in the amp connection. Try a coupling cap at the amp input and see if the noise goes away.
Old 10th February 2015, 03:28 AM   #5
Can you suggest a value? Remember the customer is very concerned about tonal coloration so the cap value would need to be such that it didn't change his tone noticeably...
bassmeknik
Old 10th February 2015, 03:34 AM   #6
infinia is offline infinia  United States
infinia's Avatar
a DC series cap is better than a series switch?
I reckon a double pole switch would be unbeatable for pure. how you hook it up... well tell no tales tell no lies
if the problem is DC i'm sure you'll find more "pure" nonsense at the source
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 10th February 2015, 03:38 AM   #7
It could be that even if there is a cap in the amp input, that its leakage current is causing problems. A large value (megohm) shunt resistor might help on the amp side of the switch. The guitar doesn't have any active electronics?
Now I am Become Death, the Destroyer of Words
Old 10th February 2015, 03:39 AM   #8
This is mainly for troubleshooting. If the noise goes away with the cap, there's DC on the input and a tech should check it.
Try either a 1uF film or a 10uF nonpolarized electrolytic.
If that doesn't help, try a 2k resistor in parallel with the switch. This will help if the amp has a very high input impedance.
Old 10th February 2015, 03:41 AM   #9
set up is as follows: guitar (passive) to an extensive pedal board then the kill switch at the end of the signal chain just before the amp.
bassmeknik
Old 10th February 2015, 03:59 AM   #10
Can you describe the pedal board?
foot switch safety question dscottguitars Tubes / Valves 10 3rd August 2011 02:09 AM
Stereo Chorus 212 foot switch problem? fender62 Instruments and Amps 0 21st September 2007 12:58 PM
Switch and Controller MIDI Foot Pedals marthaman Instruments and Amps 1 16th September 2007 05:55 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 05:07 PM
rookie builds foot switch...help needed! mihir Instruments and Amps 2 11th June 2005 02:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
