Hammond AO-39 and AO-35 organ to guitar power amp conversion - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th January 2015, 05:39 PM   #1
Smile Hammond AO-39 and AO-35 organ to guitar power amp conversion
I have two Hammond AO-39 and two AO-35 organ power amps that I am looking into converting into guitar power amps with pre and post volume controls. Any rack mount guitar preamp could be used with them. This shouldn't be hard as they are organ power amps to begin with; I'm not trying to convert them into full guitar amps. Do you have any thoughts as to where I could obtain the needed info? Best Regards! Gary DiCenso
Old 14th January 2015, 07:41 PM   #2
Well look up their schematics and attach them here.
My first thought would be that you probably don't need to do anything to them. Maybe disconnect NFB?
Old 14th January 2015, 11:23 PM   #3
Yep, the power amp part of the guitar amp is the simplest of the simple power amp. Get the schematic of your amp, then look at the schematics of some guitar amps and you can see the trend. It is very likely you can use it as is.
Old 14th January 2015, 11:50 PM   #4
Default Hammond AO-39 schematic
Old 15th January 2015, 03:01 AM   #5
kevinkr's Avatar
Since this is a guitar amp conversion this thread belongs over in Instruments & Amps where I will now move it.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 15th January 2015, 06:14 AM   #6
You can experiment with the PI balance pot to see where you like the sound most.
Old 15th January 2015, 01:40 PM   #7
One thing to consider for the A0-39 is that the signal has already been inverted(split) before the inputs. That 12ax7 is not the phase inverter tube. Hammond used an interstage transformer on the preamp chassis to accomplish this. The AO-39 is only a power amp. The AO35 does have a traditional preamp-phase inverter-power amp architecture. Here is where you can download the entire Hammond service manual: https://archive.org/details/HammondO...iesB3A-100RtDG
Old 15th January 2015, 03:18 PM   #8
Default AO-35 schematic
Old 15th January 2015, 04:29 PM   #9
Thanks guys, I did not know the phase inverter/splitter was a transformer type on the AO-39. Anyone know what to adjust or change out on the AO-35 to make get along nicely with a dedicated guitar preamp? No need for tone controls, maybe just a volume control some where and a jack to plug in a tube preamp.
Old 15th January 2015, 05:50 PM   #10
Here is one person's solution. He got rid of the extra filtering at the input. Remember, this is an amp that only processes the reverb signal for the Hammond M-100 series amps so they have extra filtering.ao35_2a (1).gif
Hammond or Everett AO-48 chassis Aidan135711 Instruments and Amps 14 11th October 2014 04:24 AM
Hammond AO-29 conversion scrimpu Instruments and Amps 21 29th May 2014 04:02 PM
Hammond Organ A0-43 to Guitar Amp cwrikard Instruments and Amps 1 14th February 2012 03:59 PM
Help me out with my organ to guitar amp conversion, please. David E H Instruments and Amps 3 24th February 2009 07:47 PM
Hammond organ..to guitar amp- vince8 Instruments and Amps 11 24th October 2005 02:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
