Fender Bassman AA864 build - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st November 2014, 05:11 PM   #1
Default Fender Bassman AA864 build
Hello,
I have done a lot of research and hope to build an AA864 head. I re-drew the circuit (helped me to work through it) and have all the parts here or on the way to do everything on it. I tried to be complete; every wire/connection that I can think of is on there, it is what I would build from.
The only changes I made (that aren't accidental!) are using only the normal channel, tube rectification (5F6A style), adjusting the last dropping resistor for the lack of the other small signal tubes, and changing from a fixed mid-frequency resistor in the tone stack to a potentiometer.
I plan to start cutting holes this weekend. Do you see any mistakes?
Thank you for looking through it,
Bill
Old 22nd November 2014, 02:58 AM   #2
Poacher is offline Poacher  Canada
Looks good to me.
Old 22nd November 2014, 03:12 AM   #3
Thank you for looking through it!
Bill
Old 22nd November 2014, 08:08 AM   #4
If you are only building the one channel you won't need the 220k mixing resistor between V1b and the 500pF coupling cap - not that it would hurt to leave it in.
Old 22nd November 2014, 01:41 PM   #5
Thank you, I was wondering about that resistor. I wondered about its voltage divider effect with the following 1M grid resistor (it is easier for me to see/understand this effect in the circuit than its blending function with the bass channel).
Bill
Old 29th November 2014, 02:52 AM   #6
Trout is offline Trout  United States
Trout's Avatar
The screen resistors?
Why the extra 220's? 470 + 220 on each 6L6GC?
Old 29th November 2014, 03:12 PM   #7
I know the schematic calls for the 470R's; as I read I wondered if I needed a little more voltage drop at the screens, or just a bit more protection from them being potentially at or above the anode voltage in overdrive conditions. Not sure if it is a good idea or not.
So it really is just one 690R, I just already have a set of 470's and was adding.
Old 30th November 2014, 04:15 AM   #8
You can use one 690R but I would recommend them to be 5 watt rating. However, if you got the 470R at 1 watt, then adding the 220R at 1 watt would give you 690R at 2 watts, that should be better than the 470R 1 watt resistors as per schematic.
Old 1st December 2014, 12:39 AM   #9
Trout's Avatar
How would wattage double when in series?
Old 1st December 2014, 01:43 AM   #10
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
It won't double because they are not equal.
That said, just use a 470r but, as recommended, 5W .
You did a right thing: never ever build the "Bass instrument channel" which is plain horrible.
Even for Bass.
You don't need the mixing 220k .
59 Fender Bassman tmblack Instruments and Amps 3 15th November 2011 07:11 PM
a Fender bassman amp question krayon Instruments and Amps 7 24th October 2011 01:59 PM
5F6A Amp build help (Fender Bassman) RichBolduc Tubes / Valves 10 14th March 2010 09:40 PM
Fender Bassman Ten Benny Bennett Instruments and Amps 2 2nd April 2009 01:01 PM
Modifing A Fender Bassman Scheme amirmk Tubes / Valves 5 16th September 2005 07:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
