novice tube amp (re)build - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 4th July 2014, 10:31 PM   #1
Default novice tube amp (re)build
Hello fellow DIYers and builders.
short version: i'm looking for help and advice building a tube guitar amp. Attached is a schematic of where I am now. It's a basic SE amp, with a pair of preamp stages on a ECC82 (12AU7) and an EL84 power tube. It works. What i'd like to do is to:
-connect the tremolo to the signal path
-add a master volume
-also, if anyone would be so kind, to point out problems with what i have already and tips where this can be improved (is the coupling sensible, the bias, etc.)
The long story:
So 2 years ago i built myself an electric ukulele, just to wrap my head around how a electric guitar works, what's the signal path and so on. While it's a crude instrument i'm quite fond of it. Mind you, this was my first venture into building something like that, and my first electronics experience.
After playing through a multieffect and headphones for a year i went out and found myself a couple of old amps. One of them was obviously a DIY effort from at least 30 years ago - i decided to make this one into a learning experience. It was a hissy and noisy rat's nest so i gutted it and went ahead rebuilding it more or less from the ground up. I kept as much of the original parts as i thought feasible. the primary and output transformers, the tubes, the speaker, controls configuration (and its what i'd like to keep in the future in this amp). I got new capacitors, resistors, pots...
For months i gleaned infromation from the AX84 site and the Valve Wizard, while soldering it together.
I'm happy that the amp works but i'm sure there ar problematic areas. I based a lot of it on the AX84, because it seemed closest to the original amp and was well documented.
What I feel are the problem areas: I was not sucessful in making the tremolo work. I'm not sure if the coupling is consistent and sensible. I tied various tone stacks for the 1 pot tone control and this low-loss configuration is what worked best. the other half of the tremolo tube is unused which feels like a waste, but i don't know what i could do with it. I'm also quite a novice in drawing a schematic, i hope it's okay.
So if anyone would like to dive into this mess (?) i'd be very happy for your comments.
Thanks,
Peter
Old 5th July 2014, 03:40 AM   #2
First off, 12AU7 is kind of a low gain tube, you happy with it?
And still on the 12AU7, doubt it has enough gain to get the tremolo oscillator started. A12AX7 would be a better choice. And speaking of the extra triode, you could use it as Fender had in their VibroChamp.
http://ampwares.com/schematics/champ_vibro_aa764.pdf
The second triode is shares the cathode resistor with the second stage, thereby introducing the tremolo. Other than that, the 10nF cap after your tone control is not nessisary, mind you it probably will not hurt. Might be better if you put a 470-1k resistor on your screen so that when the output tube is run into clipping you limit screen current. But then again, using a 12AU7 you probably are not getting much clipping. For a master volume, stick it where the 470k resistor is, use a 500k pot. The wiper goes to the output tube. Also for safety sake, put a 2,2M resistor on the wiper to ground, just in case the pot goes open.
Old 12th July 2014, 12:20 AM   #3
Hi and thanks for the reply.
I'm happy with the 12AU7 inasmuch as I'm not ready yet to try out other tubes. There are still some mechanical kinks I'd like to iron out before that - a scratchy volume pot and similar. The tubes I have probably need replacing, but they work and if something fails I won't feed bad about them.
Thank you for the tips about the tremolo. It seems that the 12AU7 hasn't been used in a tremolo so I guess that's one part of my problem. These last few days I put more research into how to couple the effect into the signal and I'd like to go for a preamp tube bias shifting trem like you suggested. But that is kind of above my current knowledge - calculating the voltage swing of the trem (or simply measuring it?) and pairing that with the cathode resistor, etc. I do like the circuit I found from a Supro s6616 (see attached), I'll try to work that into my amp.
I'll put off mounting a screen resistor for now since any resistors I put in the signal path attenuated it more than i liked (but that might have been a mistake in wiring on my part).
Attached is my updated work in progress. Please feel free to comment on it.
Old 12th July 2014, 04:06 AM   #4
You have the vibrato pot on the wrong side of the resistor, the wiper is attached to ground.
Old 13th July 2014, 04:31 AM   #5
Poacher is offline Poacher  Canada
And my 2 cents, there is no coupling cap/blocking cap from the plate of the oscillator triode to the grid of the cathode follower. See the supro schem you posted.
Old 13th July 2014, 09:40 PM   #6
whoops, thanks for that!
Novice SSE build the trooper Tubelab 35 11th April 2013 11:42 PM
Best way for novice to learn to build amp Taipan Construction Tips 22 16th December 2012 06:50 PM
Novice build of Silbury highfieldrebel Full Range 31 12th October 2011 05:05 AM
Complete tube amp novice got a few questions!! Boscoe Tubes / Valves 22 22nd August 2010 05:52 PM
Novice speaker build bull041161 Multi-Way 15 1st October 2009 07:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
