2 seperate (switchable) power stages in same amp? - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st May 2014, 09:59 PM   #1
Default 2 seperate (switchable) power stages in same amp?
Problem:
I want a 15-20 watt-ish amp, but i need a 1/4 to 1 watt amp.
(I will rarely have an opportunity to crank it.)
Rather than a master volume or an attentuator i was wondering if it would work out alright to simply design a single ended amp with 2 separate (redundant) tube power stages.
I could use a single 12ax7 as the preamp stage and then use a 3-way switch to select either 1 watt or 20 watt operation.
Would require an additional tube and an additional output transformer - correct?
Would require some careful switching to make sure that each power stage stays out of the circuit when not in use - correct?
Is there any precedent for this? Any designs i could look at? Read about?
Is there any reason why it might not work?
Old 21st May 2014, 10:20 PM   #2
diyAudio Member RIP
I'd suggest building an amplifier with a series / parallel switch on
the transformer primary for a low / high power mode amplifier.
(Assuming your 115VAC and dual tapped mains transformer.)
rgds, sreten.
Old 22nd May 2014, 12:07 AM   #3
Sreten's idea is simplest.
Other options are include a self split switch, or a VVR B+ circuit. Both simple if included in the design phase.
Cheers
JimG
Old 22nd May 2014, 12:47 AM   #4
I'm afraid i don't understand the suggestion.
I'm pretty new to this - just starting to make my first amp - and i'm not sure what the series/parallel switch would do aside from reduce voltages.
I thought that tubes had to have specific voltages and currents or else they wouldn't run properly or be damaged. I'm trying to guess at your meaning - it seems that you're suggesting cutting the line voltage to 60 vac?
Old 22nd May 2014, 01:54 AM   #5
diyAudio Member RIP
Yes. It shouldn't be difficult to design an amplifier than does 10W or
so that with halving the the B voltage still works at much lower
power, and you do that by wiring the primaries in series.
Yes you would design the amplifier to run properly at full rail
voltage, but many simple designs would still work at low
power if you halved the rail voltage, i.e. basically crudely.
Still in "low power" mode the valves would last ages.
rgds, sreten.
Old 22nd May 2014, 03:37 PM   #6
I guess i did understand after all. I am going to ask one more question because i'm still thinking that it might be cool (not easy or cheap, but cool) to have the seperate power stages.
Follow-up question:
I have already mounted a 12ax7 and a 6bg6 - the 6bg6 has an output impedance of 4.5k
I also have a 12bh7a that has an output impedance of 5k.
It occurs to me that these impedances are pretty close and that i might be able to make one output transformer work for both. If i understand it right then one would be loaded properly and the other would be either hot or cold.
Is a 5k output transformer going to be okay for both of those tubes?
I figure - since the 12bh7 is such a low gain tube - i'll probably end up close to the submini range with that one. That would be great for me. Then if i need more headroom i could switch to the 6bg6. Also great.
Alternative idea - to get a 4.5k OT. Match the 6bg6 properly and make the 12bh7 run a little bit hot.
Thoughts?
Old 22nd May 2014, 06:03 PM   #7
Tubelab_com's Avatar
You will not see a difference between the 4.5 K OPT and a 5 K OPT. Your speaker will go from over 20 ohms near resonance to below 8 ohms (assuming an 8 ohm speaker). The OPT just reflects this load to the tube which sees somewhere between 4K and 12 K with the 5 K OPT.
I have built a dual power amp in a similar manner except mine was push pull. I used a 6BX7 for the low power mode and a pair of 6L6GC's for high power with a 6600 ohm OPT. The 6BX7 is a steroid injected 6SN7 for TV vertical sweep duty. A good 6SN7 will work too.
I simply wired both output tubes in parallel using the same driver (separate coupling caps) and OPT. The amp used fixed bias. Switching was accomplished by applying a high negative bias to the tube to be shut off. This works well in my case, but the unused tube will still see the entire plate voltage swing from the other tube. A pair of 6L6GC's driven to saturation can see over 1KV on the plates with a 350 volt B+ voltage. The 6BX7 can eat this with no problem, but some older 6SN7's will spark out.
The 12BH7A is also rated for TV vertical sweep and is a good choice for this application. It can eat +1500 volts on its plate and -250 on the grid. You will need about -50 volts to shut it completely off. The 6BG6 is a 6L6GA modified for TV sweep use. It can eat +6600 volts on its plate and -300 volts on its grid. You will need about -70 volts to shut it completely off, maybe a bit more if triode wired.
I used 4 bias pots, one for each tube (or half tube in the case of the 6BX7). Wire them up in the usual manner except that the resistor that usually goes from one end of the pot to ground goes to the center terminal of a switch. One end of the switch goes to ground, the other end goes to the negative supply which was about -100 volts in my amp (from the purple wire on a Hammond power transformer).
My amp was about 2 watts through the 6BX7 and 30 through the 6L6GC's. SE would get you about 1/2 and 10 with similar tubes.
I have another amp that used cheap TV tubes for about 1 watt in low power, and 8 watts in high power. The change was done by switching from SE to P-P.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 22nd May 2014, 11:19 PM   #8
So basically i'm hearing it's been done and it works well?
I like this idea. I'm still shaky about how the biasing is supposed to work but i'm learning a little more every day. I'm pretty sure i understand. If you put enough negative voltage on the grid it prevents conductance from cathode to anode, right? (Or should i say anode to cathode?)
Thank you - thanks everyone i should say.
Old 23rd May 2014, 09:58 PM   #9
That's all you need to know. Enough negative voltage shuts the tube completely off. Keep in mind that you still have audio signal on the grid, so you need enough negative voltage to keep the tube off even when the audio signal is trying to turn it on. I had about -100 volts applied to the off tube which was enough even when cranking the amp to 11 with a pedal board.
Old 24th May 2014, 05:35 AM   #10
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Make the larger amp, then lower its power at will with a +V MOS voltage regulator.
switchable IV stages - IVYIII and Legato3 zkdaz Twisted Pear 6 19th May 2011 12:56 PM
Power amp input stages from National Calvin Solid State 1 14th July 2008 06:18 PM
Seperate power supply for pre-amp section in integrated amp? KevinLee Solid State 8 2nd February 2008 10:20 PM
Switchable stages with Tubelabís hybrid MOSFET/ 845 SE amp? rick57 Tubelab 0 5th September 2006 07:56 AM
Copyright ©1999-2017 diyAudio
