Is my speaker ok to use with my tube amp?? - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th April 2014, 02:30 PM   #1
Default Is my speaker ok to use with my tube amp??
I have a 5 watt valve head for my Guitar that I recently bought, and am saving up to buy a good speaker. For now, I want to try it out, but all I have is the 6 inch speaker from my old Laney solid state combo. I measured the resistance across the two terminals of the speaker, and it read 4.7 ohms. Is this ok to plug into the 4 ohm tap of my amp, or should I use the 8 ohm tap, or neither?
I know that its generally not a good idea to have a higher impedance speaker than the socket, and it might kill the OT, but seem as it is 0.7 volts, I have no idea.
Thanks in advance!
Billy
Old 27th April 2014, 05:56 PM   #2
azazello's Avatar
Plug in boldly.....don't worry, it's OK.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 27th April 2014, 06:33 PM   #3
Malcolm Irving's Avatar
It will be fine, but 4.7 ohms resistance is about what we expect from an 8 ohm speaker. So it would be better to plug in to the 8 ohm tap.
(The nominal 8 ohms of a speaker is a 'reactive impedance' which includes the coil inductance etc. as well as the resistance.)
Old 27th April 2014, 06:39 PM   #4
Thanks guys. Malcolm that makes sense now. Cheers.
Billy
Old 27th April 2014, 06:52 PM   #5
kevinkr's Avatar
:Cop: Since this is guitar amplifier related this thread really belongs in the Instruments & Amps forum where I'll move it.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th April 2014, 06:56 PM   #6
Ok that's fine. Thanks
Sub amp/speaker to compliment S5 electronics K 12 G tube amp xxguitarist Tubes / Valves 0 22nd April 2009 02:57 AM
6-ohm speaker to tube amp alexg Tubes / Valves 2 26th September 2006 02:45 PM
Tube power Amp matching with SAE Mark M pre amp and AR18 speaker or MS 25i soultribe Tubes / Valves 1 13th August 2006 11:08 AM
Tube amp for biamped speaker navin Tubes / Valves 39 25th November 2005 11:36 AM
tube amp/speaker match vangre Tubes / Valves 10 8th December 2003 06:06 PM
Copyright 1999-2017 diyAudio
