SS Tremelo for my tube intercom guitar amp - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd March 2014, 03:42 AM   #1
LATUBEGEEK's Avatar
Default SS Tremelo for my tube intercom guitar amp
I realized I didn't have enough B+ to use a tube oscillator in my (Iso xfmr driven) line AC supplied intercom/amp, so I built the Weber circuit. They currently aren't selling it, supply problems they told me, so I just breadboarded it. Used a 9V battery (I like single supply OP amps!) - their circuit doubles then rectifies the 6.3VAC heater voltage - just to get it up and running. Only about 1.5Vp-p, now to figure how to integrate it into my amp!
Old 2nd March 2014, 05:19 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Is that enough?
Looks like very little amplitude to do much, if any at all.
Old 2nd March 2014, 06:52 PM   #3
LATUBEGEEK's Avatar
Have been testing it, and it is more than enough! Varying grid voltage on a preamp tube by 1.5 volts (by varying the cathode bias with the tremelo) worked so well I had to put a 5K pot on the tremelo to tone it down.... Weber also has examples of inserting the tremelo in the DC bias supply for power tubes, which should notice a couple of volts up & down? Also, I'm only using a 9-volt battery. More supply voltage (up to 32 VDC) will increase output swing. You could push plate voltages around with that (perhaps - I'm pretty much still a newbie on this, but I'm learning).
Old 4th March 2014, 12:31 AM   #4
At that voltage, you should have a B+ around 150 to 180 volts DC, correct? This should have been plenty for a 12av6 based tremolo such as was included in many period budget amps.
Old 4th March 2014, 02:00 AM   #5
LATUBEGEEK's Avatar
Voltage doublers use large electrolytics at medium to high voltage ratings (not stuff I have laying around!), and I'm having good success just inserting it at the cathode. Probably will take 12VAC off a preamp tube (the last one in line - heaters are strung across 117VAC, tubes have 34, 50, 12 & 12 volt filaments), 1/2 wave rectify it, add an electrolytic, and have 10-11 VDC (Weber circuit uses a voltage doubler on a 6.3VAC winding). Best thing I've done to the original circuit is smooth out the "points" on the tremelo wave with a cap from pin 5 to gnd (thanks to help from a thread I posted on the Solid State forum!). Eliminated a "slapping" I was getting in the amp.
Old 4th March 2014, 02:33 AM   #6
Nevermind, you should have about 130-140 then, which would let half of a 12av6 oscillate. Just search for 12av6 tremolo. And also, I hope you dont change any of the current draws in the filament circuit as it will change their operating voltage.
Old 4th March 2014, 04:17 AM   #7
LATUBEGEEK's Avatar
I'm not sure where you're getting this "130-140' V from....and a 12AV6 is a single triode, so how can 1/2 of that oscillate? Yes there are plenty of tube tremelos using the 12AV6, it has a high enough mu. A 12AX7 (or a 12AT7 barely) works also, but I need a lo mu 1st gain stage, and don't want to use a hi/lo mu dual triode, so I've settled on a 12AT6 or 12AU6 (single triodes) for a 1st preamp stage, and going SS for the tremelo. Finally, taking a few mA (to run a chip tremelo) off a heater? It won't even notice it....
Old Intercom guitar amp project LATUBEGEEK Instruments and Amps 33 4th April 2014 07:02 PM
MASCO INTERCOM - GUITAR AMP PROJECT? LATUBEGEEK Instruments and Amps 5 15th January 2014 07:40 PM
Wanting to build a guitar power amp (SS/tube) kylendmkylendm Instruments and Amps 5 2nd January 2014 12:27 AM
Building a ss guitar amp! Help! mgcasella Instruments and Amps 13 8th April 2011 09:22 AM
I need a simple ss reverb for a ss guitar amp. yeto Instruments and Amps 8 18th January 2006 06:54 AM
Copyright 1999-2017 diyAudio
