Trying to build this preamp - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th February 2014, 09:38 AM   #1
lamir35 is offline lamir35  Israel
Default Trying to build this preamp
It's documented in the phantom version or normal. It only works in the mic input, and it has a lot of white noise. Any ideas what could be wrong?
I calculated the current in the collector to be 0.7mA
(I fixed the disconnected joint pointed by the arrow)
EDIT: Apparently it was miswiring
Old 1st March 2014, 03:29 AM   #2
gain wire's Avatar
Hello Lamir,
you have posted pictures of what seem to be two different amplifiers. We don't know which one is which by your pictures and even if we did, your pictures do not show your wiring well enough that we can see what is connected where.
My guess could be "with wiring/soldering like in the second picture, it sin't surprising that you have problems with noise". What I mean to say, more politely, is you can't expect to have a circuit without noise when all the leads are close to each other, nearly touching themselves.
Secondly, did you make a wiring mistake?
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 1st March 2014, 03:30 AM   #3
gain wire's Avatar
Furthermore there is no emitter in a Junction FET. It is Drain, Source and Gate.
Old 7th March 2014, 09:28 PM   #4
funk1980's Avatar
You could try reducing the 3Meg resistor. That high a value, specially a .25 W carbon will introduce quite a bit of noise. Use a 1Meg metal film instead.
Help with preamp build nonsuchpro Analog Line Level 8 27th June 2012 03:51 AM
Preamp Build robywan Analog Line Level 0 21st August 2010 01:17 PM
Build Preamp Jpoole908 Solid State 1 8th June 2008 12:47 AM
Looking for a preamp to build! Dougie085 Digital Source 7 2nd April 2008 08:05 PM
Which preamp to build skaara Pass Labs 4 13th August 2002 09:54 AM
Copyright 1999-2017 diyAudio
