Skytec TEC 6950 Help - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st February 2014, 01:25 PM   #1
Rick55 is offline Rick55  United Kingdom
Default Skytec TEC 6950 Help
i have a tec 6950 amp and i know its a china clone but was hoping someone out there could help and locate a full schematic, it is rated at 500 watt!!!.
The fault is no outputs so i would like a manual/schematic before i strip it.
I have not started anything on it yet apart from taking the top off to take the picture of the inside.
Any help appreciated.
Apologies for picture quality
Old 24th February 2014, 04:03 PM   #2
a littel more info , on the volume pcb there is a burned up resistor R1, has anyone come acroos this and any help as to its value would be appreciated, the TEC6950 has other models in the range, 6200, 6300, 6500 so a schematic for these might cover this model.
Inputs not working on skytec pro 240 amp stuart1976 Solid State 2 17th March 2011 10:22 PM
Skytec PRO240 blown output - circuit diagram? David Pinnegar Solid State 5 17th March 2011 10:20 PM
no output on skytec pro 240 amp stuart1976 Analog Line Level 2 17th March 2011 02:51 PM
skytec 6950 amp wrong specs on manual joka22 Solid State 0 15th July 2007 08:51 PM
help on param. for skytec 902.357 psychosteve Multi-Way 0 2nd November 2004 01:43 PM
Copyright 1999-2017 diyAudio
