Balanced/unbalanced line receiver - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 10th February 2014, 06:48 PM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Bigtim1966 View Post
I added the 1 meg resistor from above but it didn't seem to help. Have some parts on order to build the instrumentation amp CCT from the data sheet, hoping this will work.
maybe the chip does not have hi-z input
sometimes we know very little, and sometimes we know too much
Old 10th February 2014, 08:56 PM   #12
Originally Posted by Zero D View Post
@ Bigtim1966
The 1 Meg resistor should have worked ? If you could draw a circuit of what you've done so far, & what you're proposing, it would assist us better in helping you
We've no idea what circuit he's using, and assuming it's too low an input impedance?, then reducing it further (even if only slightly) by adding an extra 1meg in parallel will only make it worse.
Presumably you were assuming he's blindly copied the partial circuit from the datasheet?, which makes no pretence of been a full working circuit.
As you say, and as always, the OP need to post EXACTLY what circuit he's built.
Nigel Goodwin
Old 10th February 2014, 09:11 PM   #13
I will do a sketch, but in fact Nigel is right, my receiver circuit is nothing more than the figure from the data sheet, so just the ina134 and a couple of 1uf caps on the +\- supplies. And my next step was to add the two additional amps to make the instrument amplifier from the data sheet.
I have a bad feeling I am out of my depth if there is additional circuitry to be designed around these basic figures from the datasheet
Old 10th February 2014, 09:49 PM   #14
try balanced line driver
or take a look on ESP site
Old 11th February 2014, 03:01 AM   #15
Zero D is offline Zero D  United Kingdom
Hi, i was talking about putting a 1 Meg in parallel with the Positive input of the Buffer OpAmp he said he was going to use, which would better match the guitar. I wasn't suggesting connecting the 1 Meg to the ina134 circiut.
@ Bigtim1966
See my screenie for more details. Power supply connections not shown, as i'm guessing you know how to do that? ina134 details not shown, as you have the PDF for those.
Old 11th February 2014, 06:57 AM   #16
in this case it is my understanding the 1M is a safety resistor, should input be disconnected
or it could be a pulldown resistor if impedance is too high ... but you can't raise it, unless maybe you also attenuate the signal
and maybe the chip could be only 50K (still missing a number ?)
Old 11th February 2014, 08:58 AM   #17
Did it Himself
richie00boy's Avatar
It is not possible to do what you want with INA134 because the resistors are already inside the chip, therefore the input impedance will always be 25k or less.
You need to make a differential amplifier based around an op-amp with 1 meg resistors on the inverting side and 510k on the noninverting side. The problem here is that in the balanced mode the performance will be compromised by the high value resistors.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 11th February 2014, 09:24 AM   #18
Datasheets generally don't give you working practical circuits, they only give you the absolute basic minimum you require in order to design a working circuit - although there are occasionally full working examples.
Nigel Goodwin
Old 11th February 2014, 07:36 PM   #19
I wondered if the basic receiver CCT I am using is not suited to the hi-z guitar output or if I am simply using too basic a receiver CCT.
you got the answer
what now ?
Old 11th February 2014, 10:13 PM   #20
Richie has I think hit the nail on the head. The INA134 internal resistors are providing too low an input impedance for the guitar.
With this in mind I built the cct which I hope in in the pdf attached to this message.
line level unbalanced to balanced converter steevo Analog Line Level 17 16th February 2014 04:09 PM
Balanced to Unbalanced Line Conversion Loren42 Tubes / Valves 33 4th January 2011 06:31 PM
Unbalanced to Balanced Line Level XFMR wrenchone Solid State 8 22nd October 2005 09:06 PM
Balanced line stage, quistion's + unbalanced lykkedk Pass Labs 4 20th December 2002 12:58 AM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
Copyright 1999-2017 diyAudio
