Power amp without preamp stage for bass - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 19th January 2014, 07:24 PM   #1
TobiasD is offline TobiasD  Netherlands
Default Power amp without preamp stage for bass
Hi guys,
I recently build a alembic F2b copy, and now i'd like to build a small single kt66 power amp for it.
I've built the F2b copy following this scheme:
Now i'd like to cut the preamp stage out of the scheme of the power amp. Is it possible to cut out the preamp stage at the left of the red dotted line?
Is that possible?
Thanks in advance.
Tobias
Old 19th January 2014, 11:51 PM   #2
funk1980's Avatar
Sure, it's possible. I'd add an input cap though, just to be safe.
What amp is the schematic from? It seems a bit underpowered for bass.
Old 20th January 2014, 12:30 AM   #3
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
Your preamp has a .1uf cap and 1M resistor on the output.you can omit r11 in your power stage and just connect your preamp output to r10.
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Bass/guitar tube preamp with small power stage Fredde79 Instruments and Amps 16 25th January 2016 01:30 PM
12ax7 Bass Preamp Power Supply Question. bill mountain Tubes / Valves 21 12th April 2011 03:43 PM
2 stage Stereo/4 Stage Mono Triode Preamp with independent drive control & inverters sampleaccurate Tubes / Valves 10 9th March 2011 11:31 AM
bass preamp and power amp superseadragon Solid State 1 13th July 2007 07:23 PM
Quicky - magic eye between preamp and power stage Simpleton Tubes / Valves 14 10th May 2007 11:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
