Power cap for fuzz box - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 26th October 2013, 02:48 PM   #11
What we are all wondering is how will battery life be seriously compromised without a reservoir capacitor?
I can only assume that you meant that if it was unstable, or even oscillating supersonically - battery current would be increased?
John Audio
Old 26th October 2013, 04:12 PM   #12
Any electronic circuit is designed on the basis that there's a low impedance AC path between the supply rails, and that the supply itself has a low impedance.
The capacitor across the supply fills those two requirements.
Without the capacitor (or if it fails) it 'may' work when the battery is absolutely brand new, but in a relatively short time it will fail to do as, as the source impedance of the battery increases and the circuit starts to fail.
Remote controls are probably the best example? - if the capacitor goes O/C (and I've changed many over the decades) - the battery life drops from 2-3 years to only 2-3 weeks. If you replace the capacitor, the existing batteries work fine again, but not without it.
Nigel Goodwin
Old 26th October 2013, 05:44 PM   #13
You have the "right" answer for the wrong reasons.
No way can the lack of a capacitor pull more current from the battery and cause its early failure!
What happens is the battery internal impedance goes up with age and, without a parallel charge storage cap or higher ESR of the existing one, the peak current to fire the infra-red leds is not available!
So the battery no longer works in that circuit with its higher ESR.
Old 26th October 2013, 08:48 PM   #14
diyAudio Member RIP
Originally Posted by Nigel Goodwin View Post
In what regard?, no nonsense there at all.
Its all nonsense for a battery powered fuzz box.
Battery life - nonsense.
Motorboating - nonsense.
Instability - generally nonsense if the board has suitable
properly placed rail decoupling caps, typically 100nF.
rgds, sreten.
Old 26th October 2013, 09:44 PM   #15
if the original poster can post the schematic it would be helpful
Old 27th October 2013, 09:09 AM   #16
Which I never suggested.
I never suggested anything different - and even said that fitting the essential capacitor would allow you to re-use the battery.
But it's not just remote's, that's just an extreme example, it applies to almost anything electronic.
Nigel Goodwin
Old 1st November 2013, 12:39 AM   #17
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
What Nigel says clearly is that a low supply impedance is good/necessary (take your pick), doubly so in a *high gain* (any doubt about that?) , *crude* design (any doubt about that?) like a Fuzz.
An old tech 9V battery, carbon zinc is what we are talking about, will start with a relatively high internal resistance which will only go up, never down.
Which is a *known* cause for instability.
So one of those batteries will last, say, "X" days because instability raises its head, but many more days with the cap added.
Making so much fuss about that cap, which by the way was used from the beginning, as shown in the original schematic , well, *that*'s nonsense.
Or having very little to do.
Increased current consumption was never mentioned or implied, don't know where was that pulled from, *but* longer "usable" or "practical" life.
Which is the point, of course.
Old 9th November 2013, 02:53 AM   #18
frank754's Avatar
OK, here's the image. I finished the prototype. It "sort of" works, but the problem is very low gain. Even with the 2 pots all the way up, the sound volume is attenuated by more than 60% when running the guitar into the box vs running it (bypassed position) directly into the amp. When going in "notch" position, there's virtually no sound at all, but skip that for now (that makes me assume the problem is "earlier" in the signal path). As you can see, the part specs are very vague. I used MPS-6531's for all the transistors rather than 2N2222's, as that's all I had available. I'm wondering if the problem is in the transistors, or perhaps a few of the resistors can be tweaked. Incidentally, I used a pair of 1N4001 diodes for the clippers near the bottom left. As far as the resistors go, could I try cutting down the 22k input resistor, or perhaps the ones around the first two transistors (proportionately to each other) at the top left? And which stage (Q1/Q2) or (Q3) or (Q4/Q5) (I'm assuming Q6 is doing its job) would be most suspect for causing performance issues like this? I'm not an engineer, and not quite the gizmo tech freak I'd like to be, but very good at construction, so any help is appreciated
Old 9th November 2013, 09:13 AM   #19
Yes, In misread the reply. Apologies to Nigel.
Old 9th November 2013, 10:52 AM   #20
You need to find out where you're losing the signal, if you don't have a scope, then use your amp as a signal tracer. For a start feed the amp from the output of the 'drive' control, this should be considerably louder than direct from the guitar.
So try that, and report back.
Nigel Goodwin
bigger box, reduced power in a woofer box (3 way system) and overall power osd1 Multi-Way 4 18th August 2013 11:39 PM
Filter Cap Decade Box cihtog Equipment & Tools 7 17th May 2012 12:42 AM
Fuzz Face DIY: need more fuzz ThomasDIY Instruments and Amps 12 17th September 2009 03:06 AM
Want to re-box several si t amps in one box. How do I hook up to one power supply? ExJxC Class D 7 22nd September 2005 09:27 PM
WTT: Custom Box for a Battery Cap squosh69 Swap Meet 0 29th January 2003 09:15 PM
Copyright 1999-2017 diyAudio
