You are all probably going to laugh but it turns out it was a bad ground on a power supply 2200/50 cap (CR59 on the 1984 schematic). I only did a visual exam of the PCB for bad connections b/c I was afraid to do use the "eraser tab" method when powered up b/c of the "hum".
Anyway - replaced the dual diode and all is well! Thanks again for your advice!
