Guitar Amplifier Hum Varies with Volume Knob - Page 4 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th September 2013, 09:26 AM   #31
Originally Posted by tinitus View Post
if using 'onboard' active pickup pre, I suppose you should have DC protect cap on input of your pre/power/combo amp
All amplifiers should have coupling capacitors on their input, just as all preamps should have the same on their output.
Nigel Goodwin
Old 14th September 2013, 03:17 PM   #32
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
yes ... but does this amp have any ?
is your guitar bridge properly grounded ?
do you have the same problem if connecting other instrument/guitar to your amp ?
or did you try your guitar on other amps ?
sometimes we know very little, and sometimes we know too much
Old 14th September 2013, 06:58 PM   #33
This problem is very common when guitars with non-humbucking pickups, like P-90 eared soapbars, are plugged into a high-gain preamp with a lot of compression. Unless the input is shorted the compression and gain try to make the noise as loud as the signal.
Amplifier volume knob noise SatinMill Solid State 29 22nd September 2011 03:26 PM
Guitar amplifier PSU hum woes Arnulf Instruments and Amps 33 7th January 2011 06:01 PM
Amplifier Gain Varies with Frequency gni Solid State 12 8th November 2007 09:16 PM
Volume knob marob Multi-Way 9 15th April 2006 03:13 PM
volume knob Nejc_car Everything Else 3 22nd February 2006 05:25 PM
Copyright 1999-2017 diyAudio
